Discuss back boiler fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
spycatcher
Hi All, ive just aquired a coalbrookdale severn with a back boiler
there are 4 outlets at the back of it, three of them take 28mm pipe and one takes a 22mm pipe
one of the 28mm outlets i can fit an ordinary 28mm compression nut with a 28mm olive but the other two 28mm outlets and the 22mm outletseem to have a much finer thread on them
can anyone tell me what kind of a compression nut to buy for the other outlets
thanks
Second hand, with used fittings already in the back?
As above you will need to buy at least 3 new ones.
The compression nut thread on 22mm and above is usually unique to a fitting manufacturer, not BSP.
thanks for the reply snowhead
if i take these fittings out what ones would you suggest i replace them with
it says in the manual that it has 4 * 1 1/4 connections on the back
It will have 1.1/4" to 1" iron bushes in the outlets and possible 1 x 1.1/4" to 3/4" iron bush.
Unscrew the brass fittings and leave the iron bushes in.
Never saw a back boiler with 11/4 fittings
Your question shows you have little experience of plumbing - no offence intended, so I would advise you get someone with experience of solid fuel to help you or do everything. I just saw on Saturday a fire connected by someone who was a plumber of sorts but out of their depth. It is highly dangerous, with no primaries or independent vents/feeds.
The brass fittings are proving to be a bit of a problem getting out
worried i round them
instead of been selective of which replies you read and accept try reading them all please , would hate to here about you on the news
Well thats great thank you all very much
its all very well for you to say to me to read all the replies and get expert advice etc. and if i lived in a city i would probably only have to clink two copper pipes together outside my front door and half a dozen plumbers would come running but i live in the highlands in the back of beyond where its easier to catch haggis than plumbers but thats ok i'll manage
thank you all for your advice and non-advice
What you have failed to understand is the inherent danger of a solid fuel system and said system being installed by an obvious novice.
Your retort is exactly of others on here who don't like the answers to their questions. The reason why you have had no 'real' help with this matter is the fact that you don't have the first clue as to what you are doing and are therefore a danger to yourself and your family.
Here's some really good advice. Stop being tight and find somebody who knows what they are doing, before we hear about it in the news.
perhaps you should go back and read my post thourghly
the bit about i live in the back of beyond where there are NO plumbers willing to come and do the job
its hardly rocket science, i guess i'll just get my lathe out and make the nuts myself
I always find that when there are NO plumbers that will do the job it's down to the customer. IMHO.
What a strange person you are spycatcher, it must be living out the back of beyond, if it is not rocket science then why are you asking on here ?
Surely there is a solid fuel experienced engineer within 50 miles of you?
As to the seized fittings - use a blow lamp to heat outside the fittings (& a little heat on fitting) & if a spanner will slip, use grips to remove each fitting. Wear gloves to protect your hands. How's that for useful advice? :smile:
all i am asking is what nut could it be that are on the 3 other brass fittings
if you dont know then thats fine
go and harass someone else
thank you best
that sounds like sound advice
i live in the scottish highlands miles from anywhere
believe me tradesmen are as scarce as hens teeth up here
You're wanting to install a solid fuel heating system and you can't even get three old fittings off the stove...............
I'm off to harass somebody else.
thanks tamz
it looks like i'll take the advice and try and remove the three odd brass fittings
Fine threads are very likely to be the old Kuterlite. A plumber may have some lying about somewhere, but he may live too far away....
i'll try your suggestion of putting a bit heat on them
i could find a haggis quicker than a plumber out here :)
A sniff of a bundle of ÂŁ20 notes will surely attract plenty of those tight Scottish plumbers any distance?
There are mainly only 2 types of thread. Fine thread and course thread. Kuterlite, Jevco and a couple of others are fine all the rest are course. They are interchangable.
There are a couple of other different threads and but if it is less than 15 years old it won't be them.
There will be someone round about who could help you with this. There always is.
Jump on yer quad and ask your neighbours who they get to do their work.
there was a guy on the mainland but he wasnt keen on me picking him up on ma wee boat :(
I've bought most of the 28mm compression fittings and as i say the nuts on them fit one of the brass fittings on the back of the stove but the other 3 are much finer threads
Reply to back boiler fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
