Discuss Aqua panel advice please in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Tags:
  1. mutley racers
    mutley racers Plumber GSR
    So I am a virgin at using these but tomorrow I shall pop my cherry. Just after advice on installation. One side of the wall where the shower tray will go will be stud wall with the panel fixed straight on to studs. Do I build the studs flush with the tray and then aqua panel on tray like tiles? The plastered walls on left and right are painted, does the adhesive stick to paint (according to the tube it will stick anything without fixings)a and is it possible to use a thicker bit of adhesive on one side like dot and dab to make the walls square?
    Internal and external corner trims, do I need to silicone in these before slotting the panels in?
    Ceiling panels, the room I am doing is a Cloakroom under the stairs, now this has a flat ceiling for about a meter then slopes down where the stairs start. Do I cut the panels at an angle where the slope starts or can i do a series of cuts in the back and then push it up to follow the slope?
    That's all I can think of for now, thanks in advance for the advice.
    Cheers Lee
  2. ShaunCorbs
  3. Christopher buzzard
    Christopher buzzard GSR
    I'm no expert but I don't believe you can fit this panel straight to wooden studs. Done this way then the panel its self wouldnt be fitted very sercurly. Only relying on the 2" upright studs and noggens for fixture. When I've fitted them in the past it had to be to either ply or hardy backer board. Then fit the tray, silicone seal around the tray onto the HB board or ply. The aqual panel board is then fitted. Sitting on a bead of silicone left to cure for 24hrs. I then silicone around the tray, onto the aqua panel for the final seal. I always silicone the corner trims and push the panels into it to squeeze the silicone out and wipe clean with a wonder wipes.
    • Agree Agree x 2
  4. Chalked
    Chalked Plumber GSR
    Best to fit moisture resistant plasterboard to the studs and adhesive it to that. Anything like plaster, or paint will need priming with acrylic primer at 3 parts water, to 1 part primer.
    If your using one with trims, make sure you silicone every edge. Also when cutting, if your using a hand saw, cut from the face and any circular or jigsaw, cut from the underside.
    Ps. Use more adhesive than is recommended and have some timber ready to prop the panels tight back.
    • Like Like x 1
  5. Matchless.plumb
    Matchless.plumb Trusted Plumber
    As above , chuck has mentioned the plasterboard first and prime before glueing it down.
    As far as I know you can fit the panels straight onto the shower tray like the tiles. The walls have to be levelled and put a good amount adhesive behind. First fit the corner trim with the supplied adhesive before fitting the panels make sure you apply adhesive inside the trims too. You also have to make sure to get rid of the air pockets behind so press the panels nicely on. When you install the final corner trims make make sure you put silicone in so when you press it in the silicone will slightly squeeze out.
    • Like Like x 1
  6. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    I personally would not put it straight onto studs. Either ise some kind of backer board or at the very least plasterboard. Then adhesive the aqua panel to the boarding. Hope this helps
  7. king of pipes
    Yes i would build the studwork to the tray then hardie backer the area , unibond the painted walls and let it dry out completely cut the panels and dry fit them i use gripfill panel adhesive to stick the panels these need to be braced with timber till the adhesive has set , silicone the internal corner trim to the panel i dont stick them to the wall , dont normally put it on the ceiling they do a plastic cladding for that,a tub of hand wipes is a must to clean up. good luck kop
  8. Harvest Fields
    Can I ask why you do not stick the corners to the wall?
  9. Chalked
    Chalked Plumber GSR
    It depends how square your corners are. Generally, silicone the corner profile to the back panel and then fit the next panel into it. If you fit the corner profile to an in-level corner, it makes it very difficult to insert the next panel.
    Hope that make sense!
    Even easier. Use nuance boards. They have no profiles, and use colour matching adhesives. They don't bend like a banana either.
    • Like Like x 1
  10. Harvest Fields
    That's why I was getting confused all the panels I have fitted have been on square walls. Forget sometimes that nothing in old houses is square :rolleyes::rolleyes:
    • Like Like x 1
  11. ShaunCorbs
    Or new houses
    • Agree Agree x 1
    • Funny Funny x 1
  12. Harvest Fields
    Your right to be honest.
  13. king of pipes
    Chalked is right Harvest silicone the trim to the board to allow for discrepancies in the corner i am yet to have a perfectly square corner i find it works and it aviods getting excess silicone all over the trim and board and you work cleaner . cheers kop
    • Like Like x 1
  14. mutley racers
    Wow, now that is a good response. Thanks chaps. On the shower wall installation manual it only talks about sticking to battens. Nothing about plaster walls. The delivery came with shower wall adhesive which apparently grabs instantly.
    Any advice on fitting the ceiling panels to the angled ceiling?
  15. mutley racers
    Yes, I have a the cladding for the ceiling, just not sure how to cut it where the slope begins. Do you use screws on the ceiling boards? Wonder wipes it is then
Loading...
Similar Threads - Aqua panel advice Forum Date
Silicone seal on shower tray aqua panels Plumbing Forum Nov 26, 2017
JAQUAR cartridge help Bathrooms, Showers and Wetrooms Feb 14, 2018
