Discuss Anyone fitted a bidet recently? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Paul Cockhill
    Paul Cockhill Member
    Hi
    I am fitting a bidet for a client, see picture. The difficulty is connecting up when all the ceramic goes back to the wall. I think I can fit the hot and cold with flexis but am having difficulty fitting the waste. the only way I can think of doing it is to have a flexi plastic waste so I can screw it up at the wall end before I push the bidet onto the wall?
    Anyone else have any bright ideas?
  2. Christopher buzzard
    Christopher buzzard GSR
    IMG_0632.PNG Is the waste you are connecting to, going straight out of the wall or coming out from the floor within the bidet? If it's going out of the wall, you could use this
    • Like Like x 2
  3. Dkdc71
    Dkdc71 Member
    As you said flexible hoses for the plumbing and a mcalpine flexi extendable waste trap bidets are suppose to be off the wall and accessible but these days everything has to be hidden you can test while just out of position and then slide back in ,must be over 10 years since we fitted a sock washer lol that's what we use to tell the new apprentice, s they were called
    • Like Like x 1
  4. Paul Cockhill
    Hi Chris and Dkdc71, thanks for your advice. The connection is in the floor however I am sure I could use the Flexcon. I knew you guys would have an answer.
    Thanks very much
    Paul
    • Like Like x 1
  5. ShaunCorbs
    Top job on the tap, you know your water regs :)
  6. king of pipes
    Mc alpine do several versions of the flexcon one of them should suit , how are the tiles being finished off around the window ? Cheers kop
    • Like Like x 1
  7. Paul Cockhill
    Thanks KOP, yes I have found a Mc Alpine that will do the job. Dont know about the tiles, client is doing that
  8. king of pipes
    Hes missed the tile trim out its gonna be hard to make it look anything now , good luck with your bit bud cheers kop .
  9. ShaunCorbs
    Could be doing d mold tile ?
    • Like Like x 1
  10. Ant Parkes
    Ant Parkes Plumber
    Or wants an easy life with a plastic window cill that overhangs. Won't look great though.
Loading...
Similar Threads - Anyone fitted bidet Forum Date
Anyone ever change works of gate valves? Plumbers Arms Yesterday at 1:50 PM
Anyone to help with my dream Gas Safe Register Forum - Public Forum Wednesday at 10:40 PM
