Discuss any oil boiler engineers online at the mo please help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
adrianfs1
help have oil dribbling from bleed screw, the satronic lockout is not on but boiler does nothing.
trianco eurostar eco combi 65
have you an isolation valve on the incoming pipe line? either on the tank in the way of a gate valve or one near the boiler on near the fire valve on the incoming oil line?
Isolate oil supply as bob suggests, remove bleed screw and wrap ptfe around it and replace.More information on boiler not firing required, is it buzzing?
Try resetting overheat thermostat once you've fixed the oil leak. What pressure are you showing on the water side and how heavy is your expansion vessel.
thanx guys for your replys problem solved, i didnt have a leak i was bleeding it and it was just dribbling out, problem with firing was a broken wire at programmer.
Reply to any oil boiler engineers online at the mo please help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
