Discuss Any Body Specialise In Rain Water Harvesting ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
LDhiman
Hello guys.
Do any of you guys specialise in rain water harvesting ?
is it cost effective?
what, if any regular problems ?
is there a demand for these sort of systems ?
basically i have been toying with the idea of MAYBE some day building a business around them although it is nothing but a thought at the moment so please don't shoot me down too fast :p
fitted some, very problematic from my experience and seems a limited market place.
most of the rwh systems that my old company fitted on new builds got turned off and re plumbed to mains after a year or two due to the number of problems and call backs the landlords got fed up with them.
Grey water is a brown area. It's poo! Schools ect have had the fitted but as said its a freakin disaster. Far better getting involved in storage and rainwater / retention accumulators and flow restriction / hydro blocks. With new developments on old sewers the Sw needs to be slowed down as run off time too quick and needs to be managed!
Makes me laugh it is talked about as though it is some kind of new technology ?
Many old houses saved rainwater back a couple of hundred years ago !
The systems are only as complicated as the designer makes them !
My old mate used to service water rams which I know nothing about but as I understand it they are powerless pumps that work on weight of the water and gravity ?
We do like to make things complicated these days for no good reason ?
I have fitted a few and no problems at all. They are difficult to retro fit but on big refurbishments and new build no major issues. As with most things get the manufacturer to sort out the specifics and follow the MI's. On a side note all the installs I have done have been large properties that have been fully re plumbed, not sure it would work on a 3 bed semi retro fit if that makes sense.
Osma systems ok below ground but used for irrigation systems on massive greenhouses
Thanks for all the input. My thoughts mainly take me too being able to sell some sort of package deal. to joe bloggs. as has been said my main stumbling block is cost of retro fitting them
Joe Bloggs isn't going to buy it, - he doesn't even bother with a downpipe diverter.
You market place is Mr and Mrs Aspirational Grand-Design
we had a ram on the old mans farm in cornwall, simple but clever little device, water runs fm a spring down a hill and then it pushes it up to a holding tank at the top of the hill to run all the troughs for animals, used to fed the house as well.
Alsso I run 2 loos in the house here from tanks on a flat roof, fed from gutters, just means i flush for free and dont pay sewage rates :)
I've fitted a few, but as Worcester said your average customer isn't interested. It's only those with a bit to spend and who enjoy telling the neighbours about their eco credentials who would get in touch!
I see where your coming from. still something im pretty interested in. still plenty of time to toy with the idea. :)
Hiya we did alot with Rainwater Harvesting inthe 1990's and there are plenty of published articles about what we did under Aquarius Rainwater and Aquarius Water Eng - in self build mag, build it , building for a future etc.
Bluntly mains water is still too cheap as supplied to private homes - we ended up doing
supermarkets/nursing homes etc pm me if you want more info - quite happy to help
Centralheatking
Hello guys.
in ireland we are goin to start paying for our water next year..there is a huge push on at the moment to install meter boxes...people will be interested in saving money ..and to have a standard set up to accommodate the average household for harvesting could be a clever move..!!!! i have researched this before but there seems to be a rain cloud[pardon the pun] over the idea for this type of application..???? regards buf
i was thinking along the same lines. tbh tho im miles off actually doing anything. not even started working as a plumber yet lol
Centralheatking
brilliant thank you. will see if i can find the articels
I think we have some held electronically - so private msg me you email and I will get our
business mgr to put a package together - there is plenty to discuss CHK
To esp the men from the free state - regarding water meters read on.
No-one has produced an effluent meter yet - so your utility will base all it charges around
clean water consumed at your water meter - NOT how much poo you discharge.
So all the mains water you can save at your meter will pay dividends as here your poo disposal is
calculated and charged as 95% of mains water consumed and charged. Use rainwater for loads of things and then flush it away and they will not charge you - Easy Centralheatking
Is this very similar to spring water systems?
Surely u have filters inc a UV filter and a mains pump?
Would be interested in some knowledge on this is any1 can share a diagram on a basic layout?
You have seperate supply systems in the house, you only use the rain water for grey water systems e.g. flush toilets, water gardens and sometimes feed washing machines.
see here: Environment Agency - Re-using and harvesting water
However, for UK homes, it is more cost effective to save water than to reuse rainwater or greywater. Doing this will save energy and reduce CO[SUB]2[/SUB] emissions, whereas greywater and rainwater systems often increase the total amount of energy and emissions.
No prob Kooga - pm me CHK
Hi . Yes its a good idea but as mains is about ÂŁ1.65 per 1000 litres , it seems too cheap to bother with. All the renewable energy stuff is great , providing jo customer understands it, ie the rainwater filters need regular cleaning to actually allow water to deposit where its required. Cant see Lord and Lady Muck, let alone the "handy man" doing it.
I have used those Milton Rings, 1050 mm diameter x 2 metres deep/tall , on a concrete base, black jacked the inside, biscuit lid, submersible pump via a mercury switch float in loft on 1st tank, gravity feeding to larger 100gal tank, works a treat, and our annual water bills are less than ÂŁ100, that for a family of 3.
Use the jointing compound between rings and get ones with out step irons. Stantonbona cheap. Wrap with 100mm concrete and she's water tight. Just make sure it's a lockable lid ..... 2.4 children can rapidly become 1.4 !
I built my own RW system - no mains near me. Put gutters on a large corrugated iron shed (112m2 catch) with RW downpipes to a single 3600 litre black potable tank. Then boosted to the house. I put in a basic prefilter before the tank and intend installing a cartridge filter after the pump, but so far happy days, no chloride no fluoride just sweet rain. Nicest tasting water ever and no water charges! Whole system cost about ÂŁ1500
Works fine so long as the dead pidgeon and the dead mouse that the crow dropped on the roof and their guts have now washed down into the tank and are nicely festering don't cause a problem..
In Australia and NZ rain water capturing is common practice (my brother has it on his farm in NZ and my sister has one on her outback ranch in Australia, dead animal (small) and washed in bird poo are the biggest contaminants, so the water needs to be cleaned to potable standards before drinking.
Our crows don't drop their mice! And eat the pigeons.
But yes you are strictly correct. I've seen a variety of systems in different parts of the world. If you keep the catch clean and filter the water I don't believe you necessarily need further treatment. I'm only filtering out lichen, leaves and twigs. But cleaning the gutters is important, specially autumn, obviously.
In Bermuda they paint their roofs with a latex based paint and most people drink the water with no further treatment - if the roof is clean. But like here there is less pollution.
If you see no more posts from me you will know I have dropped dead from contaminated water!
just want to put it out there. Im in no way talking about making it portable lol.
The standing charge of water for us is ÂŁ10 a month, our total bill a month is ÂŁ20
The cost of fitting even a small tank still isnt worth doing unless i got the stuff free.. I wont be bothering after looking into it.. interesting fact, i spend ÂŁ50 a year having a crap..
Hydram was the name of the hydraulic pumps I worked on. Remember getting parts for it off my boss
He had gave them serial no , they knew where it was, who fitted it and the date it was fitted ( am sure was early 1900's ). They were cool peices of kit
Reply to Any Body Specialise In Rain Water Harvesting ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
Hello, I'd love some advice on my system, I've had a couple of plumbers come in that seemed to specialise in gas systems and seemed perplexed by my all-electric systems and the issues I'm having. My system is all electric heating and hot water system, in a flat on the 4th floor. The mains...
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring, probably not been used until recently now it's colder. When heating is called for, the boiler fires up ok but soon shuts down the heater as the...
hello! while saving up for a new plumbing and heating installation for my new one bedroom flat, i did a lot of research on different boilers and systems, sought some advice, and settled on a viessmann vitodens 050-w, seems to offer a lot in terms of features and reliability, offers good value...
4K
Hi, I've got a leak coming from the loft into a bedroom which I think is caused by water overflow from feed and expansion cistern (see attached one of the photos when I found out the cistern overflowing above the overflow pipe) and one other pipe that has a small drops coming out of it that is...
2K
