Discuss Antique taps - are there washers out there for these? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Matt Henry
Hello all,
I'm a tenant in a property and we have some antique taps that are shut off, because they leak quite badly. The plumbers who visited said it wasn't possible to get new washers to fix them, and a whole new unit would be needed, which the landlord isn't prepared to accommodate.
Could anyone advise if this is true? Is it possible to get new washers for old taps like these? Grateful for any advice.
Bet it's a standard 3/8th washer, givebit a go. Best off luck!
But only with LL permission!
And on old taps like these it can be a PITA hence LL and plumber don`t want to touch them.
Looks like a standard set of 1/2" BS1010 taps to me (1/2" tap washers should suit).
but as above, you don't want to break that antique corner basin it could be worth a few bob in London reclaim store.
Surely the landlord has to fix these as constantly leaking taps are wasteful and not fit for purpose as they are. Or is this just wishful thinking on my part?
Definitely. The OP said they've been turned off so presumably they have no washbasin now? I'd be complaining pretty strongly...
Reply to Antique taps - are there washers out there for these? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has been intermittently dripping from the hot tap, and the cold tap is squeaking when you turn it. Possibly two different issues, possibly related? The...
I have fitted a new set of mono mixer taps to new bathroom basin pedestal and for some reason, I’m unable to get the tap hole/base ring watertight regardless how I adjust the supplied horseshoe tap fixing plate/washers. (tested this by pouring some water over the tap base ring area and it...
1K
We have just moved in to a 1934 Semi- and I am getting round a few simple DIY tasks, including a couple of plumbing-part renewals such as modern pipe/u-bend/fittings to kitchen sink, rinse sink etc as preventative maintenance! Nothing complex or specialist, that's for you expert guys! But in...
I've attempted to replace the shower hose from our Aqualisa Lumi electric shower unit. The new hose is badly leaking water out from the connection point and when I reattach the old hose it is now leaking too! Both have been tried with new washers and are as hand tight as they can go (wasn't a...
1K
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked very corroded around the tap handle. An Anglian Water engineer was at the property measuring my water pressure and flow rate. When he saw the...
