Discuss Alpha Specialist Required in Brighton in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
My daughter and her husband have just bought a house in Brighton in which the previous owner had installed an Alpha 25C boiler........
The heating failed last week (hot water still available) and the engineer diagnosed a faulty diverter valve head because there was a slight leak from the diverter valve. Valve replaced (replacement part cost £90) total bill - £276.
Two days later still no heating! The poorly designed wireless thermostat (Alpha 24 hr Easystat) is demanding heat, the red light is showing on the boiler, but no hot water for the heating system is being produced.
We are awaiting the return of the engineer who diagnosed the problem last week, but in the meantime are looking for a heating engineer who does not make a sharp sucking in of air noise when he realises that an Alpha has been installed!
not sure of his location but there is an alpha specialist on here known as alphaman try asking him for advice.
Reply to Alpha Specialist Required in Brighton in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The existing pump flows downwards. The manual for the proposed replacement recommends that it should pump upwards. This would involve rearranging the flow &...
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter valves (all about 10 years old). We also use a Hive thermostat.
 When I boost the hot water with Hive, the receiver near the boiler shows it's...
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd, London. Job Description: Problem: The boiler is not providing heating under normal conditions, although hot water supply is fine. Interestingly...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for heat, the boiler fires up, modulates, but jumps very quickly (about 30 seconds or so from 40'ish all the way to 70, burner disengages putting it the...
