Discuss Air admittance valve black in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
maxthedog2014
Hi Guys,
Just a quick question, I understand the external soil stack regs for a open vented, my customer wants me to fit a air admitance valve on her new stack which i'm putting up. It will be external inbetween two windows . my question is do i have to go past the guttering, for some reason i'm thinking it only has to be 1m above flood level eg bath? Thanks for your help on this :)
Doesn't need to go above gutters about 6"-12" under soffits is fine
But be careful some aav can only go inside get one for outside
If its A1 designated it can be fitted bellow the flood level aswell, if you are going to run it up past the guttering you may aswell vent the stack instead, if its within 3m of an opening vent 900mm above it.
Reply to Air admittance valve black in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, grateful for your expertise on the following. DIYer, not pro. Rural property in France Single storey. Septic tank. Late 80s construction with concrete slab subfloor. All of the waste pipes run in the concrete, and exit the property at the chamber as pictured, just outside the building...
J
Hi, I am installing a new en-suite toilet upstairs in a new location , the soil stack is installed by my builder going downstairs directly and into the ground where the main sewers are. He’s installed the air admittance valve on the floor below , which is slightly below where the toilet is...
1K
Hi I want to fit an external air admittance valve to a new stack pipe, see picture. Does anyone have a particular recommendation. Many thanks Paul
1K
Hi, I'm new to the forum and just some background on myself. I have 4 years experience as a plumber but haven't worked in the trade in 15 years. I would say my overall knowledge is not great as I did most of the 4 years working on rinse and repeat estates of houses. I was also quite young and...
Hello, DIY plumber here, I’m after some advice regarding an AAV, my current one goes though the loft and the roof with a vent on, iv seen on some pan connectors have 32mm air admittance valves built on to them. Does this mean I don’t need the 110mm pipe into the loft at all? TIA Tom
1K
