Discuss Advice on Re enamelling a bath tub in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. mutley racers
    mutley racers Plumber GSR
    Hey guys. Have a bath that has a wall built around it and want to know if any of you have attempted to scrub up a dirty bath and what products to use?
    Cheers all
  2. rpm
    rpm Trusted Plumber
  3. king of pipes
    Google the bath doctor cast iron baths can be re enameled. Kop
  4. 64degrees
    64degrees GSR
    Just had an original cast iron bath refurbed on a job. They don’t put it up on bricks and heat it till glowing anymore, it’s sprayed on.
    Rather than spray it while the house was a building site they preferred to wait till job finished and tape everything up. Cost around £500. Bath Doctor as KOP said.
  5. mutley racers
    Thanks for replies guys. £500 A fair wack.
    RPM, does this bath look like it will scrub up?
  6. mutley racers
    Bit of a nightmare having to change those taps isn't it
  7. rpm
    rpm Trusted Plumber
    Cut a hole in the room next door?
    Certainly a mess there, I'd go with watered down Kil-rock in a spray bottle and a sponge over time then a HG cleaner.
  8. mutley racers
    Over time, it's just a get in and out job so couple of days.
    Agreed, chop out the bricks to get to taps
  9. townfanjon
    townfanjon Trusted Plumber GSR
    Try some cemtex !!
    • Like Like x 1
Loading...
Similar Threads - Advice enamelling bath Forum Date
Advice for heating system to install Central Heating Forum Thursday at 9:23 PM
advice re keeping combi boiler and adding a booster pump Central Heating Forum Jul 2, 2018
