Discuss Advice on new oil tank size camray 5 19-26kw boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I have been asked to quote for a new oil tank. The house is a large 3 bed . It has a standard camray 5 19-26kw boiler. Also has an arger. I don't do much work with argers and unsure how much oil they use.
The access to where the tank will go is narrow so thinking of tall thin tank.
Any advise on what size tank
Thanks Ray
Tank 6' x 2'x 4' would hold 1000 + litres and suffice in most domestic situations. Heat from AGA would offset demand from boiler. With space at premium, tank can be made to special order with 6' dimension as height. Provide safe step access for operative to fill.
Having had past experience of delivery driver refusing to fill a new tank because it wasn't connected, (filter, shut off valve plus blanking plug, all in place) I now bury a length of outlet pipe in ground to avoid arguments.
A lot of people I find do not order or store much kerosine nowadays. Therefore most people have no need for a 2500 litre tank, - but ask the customer. Also always consider 2 tanks, - one of which could just do Aga. Got to be careful if you have just one pipe from one tank supplying an oil burner plus an Aga. Risk of affecting oil in Aga.
I personally think oil tanks need to be at least 1200 litre to allow customer to order 900 litre (which is slightly cheaper way to order) while still able to keep enough oil in tank.
An Aga in my opinion is hard on fuel and constantly uses oil - approx same as modest consumption of a pressure jet oil burner that heats entire house.
You can get the normal oil usage from Aga specifications if you look up exact model.
Oil boiler burner 26kw will be approx 2000 litres a year if well insulated house with average use, but it could be less or more depending on customers wants
Reply to Advice on new oil tank size camray 5 19-26kw boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler. Initially we thought the boiler may stay in place but after discussions with the builder we would have to move the boiler to replace the floor and...
Hi, We have a large Heatrea Sadia unvented hot water tank, not sure of the size in liters but its about 1600mm tall. The tank is around 3 years old now and was amazing when it was first installed. Around a year ago we had a problem with water dripping from the overflow pipe outside and we ended...
Hi all, sorry about the long post but a novice here looking for some advice... I've just bought a 12 bedroom private house with 3 bathrooms that we're turning into a guesthouse. The property was built in the 1970's or so and has an oil fired boiler with a standard copper cylinder. As far as I...
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig cupboard & a megaflo (no tank in loft). However the exisiting boiler is Vaillant ecoTEC 4xx boiler - which is satated by vaillant as an "open vent" boiler...
Having a few issues with my combi boiler, its 14 years old now and due to be replaced as we are building extension, but need to get another 10 months out of the combi yet! Was having pressure and lockout issues and the relief vale had activated couple times, expansion tank is fuel of water so I...
