Discuss Advice on core drills in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need to cut a couple of 40mm and a 32mm hole in a 9" solid brick wall over the next few weeks, and am weighing up buying tct or diamond core drill bits to drill these rather than renting from HSS or Jewsons's. I have an SDS+ drill with clutch already so the difference in cost is small, and I have the core drill bits to use when I need them, which is usually at the weekend. TCT bits are much cheaper, and seem fine as the bricks are standard soft house bricks, and I only want to cut a small number. Is it worth using diamond cores ?
just hire a core drill n core, or buy a tct core for your sds which is too slow for diamond coring
Tct won't be as neat as diamond.
Unless your doing a lot or drilling hard walls just buy a cheaper set and use your sds. I used mine for years with diamond upto 5", yes it took a little bit longer and it will wear the drill out a little bit quicker but it will do the job.
If you are drilling a lot buy a core drill and decent bits. If you only need to drill a few through hard walls hire one.
re wearing out sds drills, it took screw fix 6 replacements to cotton on and me one stiched up face to realize sds and diamond arent very clever.
Cheap way out is sds and tct. Diamond with sds will work until you come across really damp bricks, or a course of engineering bricks
52mm diamond core bit will do for both size pipes and allow movement and tolerance. If drilling damp bricks diamond matrix can become clogged, but easily cleaned by using core on dense concrete block or similar to expose diamonds. Do not use hammer action.
From what some posters say, using sds+ drills is risky with diamond core bits ? Is that because the bits or drills break ?
For two holes just machine gun it. Mark your circles and drill series of holes, 7mm, around it and then use chisel on sds drill to knock out centres.
The sds mechanism can be too aggressive so the segments of the core bit can snatch in the material, and if your clutch is a bit firm it could send you spinning or worse break something especially on the larger diameter cores.The "teeth" of diamond core bits are really no such thing, they are not designed to cut and quickly remove material just abrade.
Either type of bit will be fine as the diameters are small, if you're not going to use them again go for the cheapest option.
Just to finish off this post, I bought a cheap set of diamond cores, and they worked fine, nice clean holes, and in fact I also cut an extractor fan outlet with the same set. The clutch worked fine on the drill too when the bigger core got stuck.
Reply to Advice on core drills in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi all i need some help and advice i am tiling around 2 shower pipe fittings. as the measurements were intricate i was practicing on off cuts and trying to create a template. I've noticed when i drill holes into the tiles sometimes they would crack. i don't use any pressure or drill too fast...
1K
I'm currently refurbishing a room and in the process adding some internal wall insulation. The wall has been stripped and my plumber is coming this week to install/reconfigure the pipework for new radiators. The walls are solid brick and as I am installing insulated plasterboards, we agreed...
3K
Alright my plumbers from another mother Know it’s been asked before but what core drills are people using. I need to bite the bullet.
8K
Hi guys, looking for a bit of advice. I'm experimenting with heating solutions for my outdoor potting shed & workshop & I'm putting together an electric tube heater connected to copper heat pipes. Now I'm starting off small just as an experiment to see if I can do it & then upscale if needs be...
Morning All, Just after some advice as I have been asked to plumb in a sink and washing machine waste for a new kitchenette. The other side of the stud wall shown is the bathroom, with the toilet attached to the soil pipe bottom right and a small basin attached to the 32mm waste. The wall is...
2K
