  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss Advice on best solution for pump for 2 showers in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. marc1977
    marc1977 Member
    I currently have one pumped shower and one gravity fed. I want to add a pump to that one too. Is it best to have 2 separate shower pumps or a new 3.0 bar pump that can run both showers?
    The current pump has a direct 15mm feed from the cold water tank in the loft and a 15mm feed from the top of the hot water cylinder. It would be good if I could re-use these pipes for both showers however I wonder if they need to be 22mm if Im going to run 2 showers at once. so in short
    1) Can a 15mm feed to a single 3.0 bar pump run to showers?
    2) If not should I swicth this to 22mm OR just install a speate pump and new hot and cold feeds?
    Marc
  2. johnf
    johnf Active Member
    Hi Marc
    15mm cold feed should not be used for a cold feed for one pump let alone two. Stuart Turner pumps have a good technical team and if you give them a call they can advise you well on this.
    • Like Like x 1
  3. Plumbstar Tom
    Plumbstar Tom Well-Known Member
    I think you would have to consider increasing your cistern size too. two power showers use water up very quickly
    • Like Like x 2
  4. marc1977
    marc1977 Member
    OK thanks - I read that about the cistern size however we have the same amount of showers now, just one after each other so dont think it will be a massive problem.
  5. Plumbstar Tom
    yes but one is gravity fed and now it will be a power shower so it will be using water a lot quicker. If you run that pump dry it could write it off
    • Like Like x 1
  6. marc1977
    marc1977 Member
    ok thanks
  7. marc1977
    marc1977 Member
    i mean we only use the power shower now but have 3 showers in a row but there is enough hot water
  8. Radioman
    Radioman Active Member
    Yes but your CWT supplies hot and cold to the shower. What size is the current tank?
  9. marc1977
    marc1977 Member
    50 gallon
  10. Radioman
    Double up on cold water storage.
Loading...
Similar Threads - Advice best solution Forum Date
asbestos water tank and cracked wood support advice Plumbing Forum Jan 8, 2017
Advice on best route for 28year old Plumbing Courses Apr 12, 2016
Best system advice for new house Central Heating Forum Feb 22, 2016
shower pump advice Bathrooms, Showers and Wetrooms Thursday at 8:50 AM
General Advice please? Plumbing Forum Tuesday at 9:22 AM
Looking for Shower with Body Jets advice - homeowner New Member Introductions Jul 14, 2017
Direct unvented cylinder quote advice Plumbing Forum Jul 9, 2017
