Discuss Adjusting temperature on this type of radiator valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
In my flat I have two types of radiator valve, one that can be adjusted just by turning and a different type of valve (shown in pictures).
Sometimes I want to control the temp in different rooms. If I want to adjust the temperature on these radiators, is the only way to unscrew them and manually adjust the temperature with a spanner?
Thanks.
These are not much use i am afraid they are either on or off , you need thermostatic radiator valves fitted to have tempreture control. Cheers kop
Reply to Adjusting temperature on this type of radiator valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
