Discuss adding heat element to solar system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
wigz
hi, a customer has asked if i can install another cylinder into their solar system as the water is not always hot enough. not been to look at the system yet
but don't the system usually have a way to heat the water other than solar, maybe a immersion, just wondering what is the usual cause for action here?
maybe install unvented cylinder for hot water. or maybe a new cylinder with immersions ? thanks
Hi Wigz
Yes there would always be a back up heat source, I know this may amaze you, being on the sunny south coast but it doesn't always shine.
There is two normal ways to achieve this in solar systems, one is to have a solar cylinder as a pre-heat to your normal HW cylinder so water goes into solar one first then out into a smaller normal direct or indirect one. The second is to have a re-placement solar cylinder which have a greater capacity than normal ones if indirect heating is available from the CH then they will have twin coils the lower being the solar & the other (CH) around half way up positioned so that it will just heat enough HW for the day. Same thing with indirect back-up immersion would be half way up cylinder.
Hope this helps.
thanks for the reply, the customer is saying he don't have a back up as the water is not always hot enough from solar.will take a look monday and try to advise him, if he has no back up he has a couple of options
but all involve replacing cylinder. are all the cylinders used for solar unvented???
Was looking on net to see how another cylinder would be connecte
Into the excisting system. Will have a look at his system set up first .
Thanks chris
Thanks chris
Depending on the type of cylinder it may be possible to fit a Willis immersion heater strange name as they are fitted outside the cylinder, very popular in Northern Ireland.
Try This Link or Google for local stockist.
Reply to adding heat element to solar system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
After some advice, i have recently had solar panels fitted and have an Eddi which uses the energy we generate to heat the cylinder using the immersion heater. Just wondering if there are any devices that can circulate the hot water in the cylinder so the immersion heater heats all the water...
Hi, I'm looking to purchase a 300L unvented indirect cylinder to work with a standard heat only boiler. I may have solar panels in the future, but likely the PV kind rather than the thermal kind, and won't be having heat pump in the future. So the cylinder would be connected to the boiler at...
Hello Everyone, I have customer with solar that doesn't seem to be working so only gets 1/2 a tank of hot water which is heated by the central heating system. She can't find a company to come out and service the wet solar system and she is looking at getting loft conversion in the future will...
I have just had a new boiler and 210 ltr unvented tank fitted in the loft to replace a very old Baxi back boiler. I have now fitted a Solic 200 diverter to utilise all the spare capacity from the 3,84 Kw Pv system on the roof. This has only just become an option as the old existing tank did not...
During an install of new boiler ('old' boiler died after 11-12 years) the system was "drained" but I guess maybe 90% of water was left in the (rather large) underfloor pipe system. What is the best way to tell how much inhibitor should be added in this case? (also taking account that system was...
