Discuss Accumulators? Simple??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
spikewt
Are accumulators as simple as redirecting the mains from the unvented cylinder thru the accumulator then back into the pressure reducing valve to the cylinder giving equal pressure accross hot and cold??
Or am i missing something?
it's so you can boost the pressure by use of a pump on the mains i think
Im looking at one without a pump. Iv got 3 bar and 14 lmin but it on 15mm mains. Looks to me like you jus run the mains thru it to the accumulator. With non return valves.
I made a few enqs on these a while ago. Can't remember the company but they were very helpful. You have to connect it to the mains after the kitchen tap. You then need to set the pressure at whatever the highest pressure of the house is. you need to test the pressure at varying times of the day. if the highest pressure is 2.5 bar then you can set it at 2.5. That is the pressure you'll get. Apparently.
mains in to acumulator mains out to pressure reducing valve and then to unented cylinder ,the job of acumolator is to maintain same pressure during peak and off peak hours ,works good the one i fit could not adjust it but did good job
Thanks blod. Thats the sort of thing iv been looking for. I had it in my mind roughly how that looks. In gonna get a horizontal one an stick it in the loft i think. Ill lift all the insulation from under it an jus lay it over so it shouldnt freeze.
If you've got a small loft hatch you can fit smaller ones in series. Advanced water have a good selection of different sized ones.
i was told recently these dont comply with water regs as they are effectively a dead leg
I'd agree they are a dead leg, but would that then mean all the unvented cylinders fitted with expansion vessels don't comply with regs either ?
Yes, that's correct. It will store and delivery water at your static pressure. i.e. 3 bar.
Just checked back on the TWS siste - any one found where the demo has gone? The website has gone all consumer instead of technical ./ installer, and I don't see that wonderful graphic that they used to have :)
Got one we need to install for a farmer.
Reply to Accumulators? Simple??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If changing a combi boiler system to a heat pump. What do they usually do with the balanced cold connection on the hot water cylinder? Cap it. And put a pressure reducer on the mains so they have equal hot and cold pressures? I can't see them repiping a balanced cold from the cylinder to each...
Hello, I'd love some advice on my system, I've had a couple of plumbers come in that seemed to specialise in gas systems and seemed perplexed by my all-electric systems and the issues I'm having. My system is all electric heating and hot water system, in a flat on the 4th floor. The mains...
Hello, I am fitting new taps and a shower mixer in my en-suite and was looking to isolate the hot water pipes. I have an unvented indirect heating system (have attached some photos). I was wondering if the isolation valve that would shut off the water to the hot water taps is as circled in the...
M
I have a viessman vitodens 222F combi storage boiler on the ground floor. It has 100l capacity inbuilt cylinder which is delivered on mains pressure. I bought it hoping I could have two showers across floors running with hot water even if it’s a short while, while avoiding an unvented...
Max Hill
M
Hi everyone, Gas combi Boiler Mains fed in all taps and shower How do I balance the water pressure in all faucets in my flat. Every tap/water faucet is mains fed but the cold water is really strong in every tap that if I open the tap fully it flies out like a fountain but the hot water is not...
