Discuss 65 or 90 degree fire valve for Rhino Boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm looking to fit an external fire valve to an older style 'Rhino' boiler (re-badged Firebird??) Bog standard cast iron, balance flue conventional boiler. I was wondering if a 65 deg fire valve might be prone to nuisance tripping on an older design like this and if so, might it be a better bet to go for a 90 deg jobbie. Any thoughts?
Depends really on how well insulated the boiler shell is.
If you had plenty of time, you could put a thermometer inside the boiler house and take the temperature when the boiler has been running long enough.
Or if it looks highly likely to be too much heat, use the 90 degree firevalve.
Think regs ask for valve to be a metre or more away from boiler house, so you need right length of capillary.
Where you put the sensor is likely to make a difference.
Yes, a thermometer would give a good indication but at this time of year the boiler is just firing for a very few minutes at a time so that might not give a true picture of how hot it might get in mid winter going full whack for longer periods.
I dropped an email to Firebird to see if they had a recommendation and their technical dept reckoned it would always be best to fit the 90 degree valve so I think I'll go with that.
Many thanks for your thoughts.
Please ensure you log in using your correct user name. Posts by unregistered accounts tend to get deleted.
Reply to 65 or 90 degree fire valve for Rhino Boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can I pick your brains? My boiler is often reluctant to start, sometimes it does, sometimes it seems that it will if the demand is from the central heating but not for hot water and sometimes the other way round, so it's probably just luck as to when it does decide to work[?]. When there's...
1K
A bit of an unusual topic, as these are very rare in the UK. I went back to Poland to commission, test and tune the 20kW solid fuel boiler and the domestic heat exchanger for the hot water tank (300litres). Old heating system with steel 2-inch pipes and cast iron segmented rads We were warned...
I don't work now due to being ancient. I looked at a 'Range cooker' fired on kero. It had a slow leak that turned into a bad leak in a month! It had a welded fabricated boiler. I've seen such heat exchangers leak within 7 years from new. No wonder the Potterton heating production manager said...
2K
Bit of help on the regulations please? An external oil boiler (metal case) sited outside the house but contained in a slightly larger wooden enclosure (foot bigger in all directions, ie not a shed). Would it be acceptable to place the fire valve inside the wooden enclosure?
5K
Hi All, I have a Firebird Enviromax external oil boiler, it has a Riello RDB2.2 C26 burner which keeps locking out. It has been an ongoing problem, where I've had to call my local guy several times. He gets it going, but it doesn't stay working for long. Its costing me a fortune for his time...
5K
schubes18
