Discuss 3/4 Brass coupling with nylon thread, why? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Plumb Duff
Hi all, I recently got with a pressurised water heater connections consisting of 3/4 brass nipples and brass couplings, the coupling has rubber seals and nylon internal thread, why would this be the case and can I not just directly couple to the water heater without the coupling supplied using 3/4 elbows to the water heater with the nipples fitted? What is the purpose of the supplied coupling? (attached photo)
I should perhaps clarify it is the nipple that is designed to first connect to the water heater then the coupling into that, if I can connect direct to the nipple with an elbow (and this would be the preferred way due to space constraints) then I don’t need the brass/nylon coupling?
In reply to SimonG (thank you) surely the heater protected from damage by the nipple? Correct me if I'm wrong.
Jcplumb is absolutely correct and the warranty is worthless without them.
JC yes that sort of makes sense to me as it looked like it was designed for electrical isolation (albeit water is a conductor) having said that I'm using PVC covered aluminium pipe and it would suite a lot better if I could use the supplied coupling a couple of metres from the tank as opposed to directly onto it, would it make any difference... in your opinion?
It's not for electrical insulation it's to stop corrosion caused by dissimilar metals.
Advise duly taken they will be fitted, many thanks to all that replied
To be fair them ones look decent ones, normally there a bit of formed plastic just normally bin them as the tails out the heaters are plastic any way :s so no need and they always break/ snap as they can't take the heat and cooling
Ariston water heaters
also are you G3 registered as any pressurised water heater needs to be installed by a G3 qualified person
Reply to 3/4 Brass coupling with nylon thread, why? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise coming from my copper water pipes when no water is being used? It basically sounds like the noise you hear after the water shuts off when your toilet bowl...
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a steady stream without stopping. Seems to be coming from water heater but I cannot tell. It is cold water. When I turn off the main water supply, it...
Pritesh Patel
I wonder if anyone can help, I've tried several plumbers merchants to no avail. I have removed an old stopcock, (which seized long ago, with a newer stopcock just above) as it had been leaking from several places, mainly at the bottom where it joined the 3/4" threaded female end on rising main...
2K
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution I could see. I'm in Brisbane, Australia but I'm after general ideas from anyone here or in UK (I realise this is a UK based site). Point form...
Hi, I've looked through old threads on similar questions, however i was hoping for advice regarding our house project. When i've read threads before when people have asked similar questions - some people say that the Veismann Stored combi is a great boiler and would be adequate, however most...
2K
