Discuss 2nd shower feed in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Tags:
  1. CP1111
    CP1111 Member
    Fitting a 2nd power shower onto gravity system without fitting a pump
    should I cut in a 2nd feed direct from the cwsc and at the same height in the tank?
    Regards to the hot supply, as bath is being replaced by the shower, can this be used? Or would I need to run a separate feed, & should this be teed into the hot for shower 1?
    Both tanks to be increased in size
    Any advice would be much appreciated
  2. ShaunCorbs
    Yea straight from the tank and cylinder for best results
    • Like Like x 1
  3. CP1111
    CP1111 Member
    Will it make a noticeable difference between running the hot up to the shower, or coming up out of the cylinder, short run across attic then down with the cold feed?
  4. ShaunCorbs
    How far off the joists is the tank ?
  5. CP1111
    CP1111 Member
    Approx 30cm, but I'm thinking of building it up higher
  6. ShaunCorbs
    If you can the more the better
    And with the hot run it down don't go into the loft if you can
  7. CP1111
    CP1111 Member
    The hwc is going to be moved lower by about 2foot, do the pump & 3way need to be lower in height than the top coil feed, or just lower than the vent?
Loading...
Similar Threads - shower feed Forum Date
How Can I increase shower drain flow rate Plumbing Forum Wednesday at 11:18 PM
Replace bath & shower mixer tap diverter Valves & Taps Monday at 7:14 PM
