Discuss 28i greenstar junior lockout in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pipefitter
A bit of advice needed please ,been to look at a greenstar 28i junior & it is locking out in heating mode only ..hot water mode is fine .
Flue is ok , condense pipe is clear ,inlet pressure is good 22mb & getting a 2.5mb drop when running at full load ...
It runs for about a minute or 2 then lockout ,I'm getting light normally off then blue flash which indicates ignition lockout,but why only in heating mode?
Keeps going to lockout until its cooled down(5mins) then it lets me reset it
I've left it with heating switched off & it's running fine ( hopefully till Monday)
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to 28i greenstar junior lockout in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hoping someone can give me advice with this one. At an annual gas service today I found a Worcester Greenstar Junior 28i to be using only running at around 12kW on high when carrying out the gas rate. The CO readings were where they should be, fan speed was okay and inlet working pressure was...
2K
Hello, Newly moved into a house with a mains fed cylinder system. I've never had one before and struggling to get it working. When I turn either heating or water off at the timing unit, the other works fine. Eg, with heating off, water works and vica versa. The indicator lights are solid blue...
Hi I have a Vokera 15 vhe boiler and all has been running well for the last 6 months since moving in up until a few weeks a go. Boiler throws up a flashing 79 code. Try restarting the boiler straight away but I have to wait 10 minutes for it to cool down before it works. I reset the boiler...
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the existing boiler needed upgrading. The Mechanical Engineers advising the architect insisted that we had a conventional cast iron combustion chamber boiler...
1K
Hi guys. A couple of things. 1 am I better fabricating bends in 14 mm copper for my ch or are 90 degree elbows fine, ref flow, friction ect. 2 my ch boiler, non condensing is playing up, I can get hot water, but when heating is on pipes only get hot for 1st mtre or so? I can hear feel the...
