Discuss 2" solvent weld waste pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
storeyn
Hi All...I am doing an bathroom installation that has a 2" solvent waste pipe in it that I need to relocate. I thought it was a standard size so bought new elbows etc....it turns out that the installed pipe which has solvent weld fittings has an external diameter of 51mm (hence 2") but the fittings, I can find that are advertised as 50mm ones (assume this is the internal dia) are actually 55mm external dia so are too big to fit. Fortunately I spotted this before cutting the pipe as it is also the main waste for the kitchen. Just wondered if any anybody knew where I could get 2"/51mm fittings from....
Hi Ray Thank you for your response, however for some reason I can not see the picture or link you have posted...Cheers
Reply to 2" solvent weld waste pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
