- Messages
- 194
1) And I'm embarrassed to ask this but, what's the simpletons way of defining pressure and flow rate. Because I have a job with poor flow rate which gets a lot worse when 2 or more outlets opened but 3bar (it's an unvented system so I was surprised at the poor flow rate)
2) I'm getting 16ltrs which reduces to 12 when I go through the water softner. How can I increase this.
A its unvented even at 16ltrs that's not enough. My thought was stick in a cold water boost set with break tank but wondered if you guys had a better idea. Monies are no object but I don't want to charge the client for this when there might be a far simpler and lower cost option for them.
Thanks as always.
Thanks as always.
