Discuss Best pipe tube carriers - how thief proof are they? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Marco
I've got by fitting a few 3m lengths of pipe in the back of the van upto now as have to park on the road abd thought it was safer and cheaper:). But they always seem to be in the way!
I've looked at the pipe tube carriers and wondered how safe they are ie they are an advert to thieves and even if locked/padlocked they only seem to be clipped to the roof rack, so easy to remove or force open.
Rhino look popular. What do people like to use? how safe are they?
Cheers,
Mark
i use the truk rax type which ever one you have they are not theft proof
I have a Rhino on one van and a bit 4" with a glued blank cap on the front and a screwed access on the back on the other. Both work just the same but you can get more in the rhino. A 4" pipe holds a bundle of 22mm and 15mm with a bit space for a couple of other lengths. If they want in they will get in no problem. You can break the lock of a rhino with a screwdriver.
Cheers Gas man - The truk rax one looked alright and a bit more room than some? I've got their roof rack which has been good
Cheers Tamz - Thought about the cheap and cheerful 4" soil pipe option. It might be a good compromise when going to a bigger job, and the van is crammed. Just will have to unload at night, but easy to forget when worked late and its raining!
my uncle has been using 4" soil pipe for ages, don't really know if he has had anything robbed from it but his mitzibushi warrior isnt really signed with "plumber" on it
its been ok,not been nicked yet and its the cheapest tube carrier you can buy
If you have a flimsy cap at the front they make great torpedo tubes if you brake too hard ...
Was in a smash years ago and the front cap only cracked. Nothing came through it. Smashed plenty throwing lengths of half inch in.
If you are making one it is best with a glued external access cap at the front too. When you spear a length through it, swap with the cap from the back. Nothing comes out the back.....normally.
i have used soil pipe for years now, as said before make suse you glue on and not pushfit. On saying that i try not to leave copper on van over night, too expensive.
P.s. If you have a spare ladder clamp you can use it to clamp 2 4'' soil pipes to the roofrack and easy take off if needed in no time at all. just make sure you clamp it down well and lock it.
I think I'll go with the 4" soil pipe on the roof and keep the plastic in it, and built a piperack in the back of the van for lengths of copper hidden from view
Pipe carriers are a magnet for theives and I wouldn't entertain one at all. My van is long enough to fit pipe inside covered up with dust sheets etc.
I invested in Rhino pipe carriers, they look good but that's about it, one key fits all locks not that you need a key. Just pulling the catch down works just as easy whether locked or not.
i have a 4" pipe on my rack which is where all the plastic lives, couple of lengths of solvent weld ie 40mm with a 32mm and overflow pipe inside it then easily 10 lengths of 22mm with the same again of 15 inside that too! works well. and i have a glued socket at 1 end with a glued cap in it, never broken in about 3 years or so now. and other end is the female end of the 4" pipe and i just shove a glued cap in there so its easy too pull in and out just held on by the rubber, alot better than squeezing your hand in trying too grab pipe through an access cap. 1 tip is get the 4" pipe cut down a little bit so the 3m lengths fit pretty much perfet else it can be more arkward trying to grab stuff when its 3 or 4 inches further down the pipe than it should be. can tell ive had alot of experience with these!!
Hi. At the discretion of the forum moderator, I'd like to respond in a constructive manner to concerns raised in this thread about the Rhino Pipe Tube. As an engineer from the Rhino Products Technical Team, I can offer informed advice and technical support on product issues such as these (if that would be helpful?).
The model you are describing is the first generation of Rhino Pipe Tube. This was replaced in early 2008 with the current model (although stocks of older models may have taken a few months to filter through the system). The current model has steel bulkheads behind both nose cones, and has an improved (patented) locking mechanism with hundreds of key combinations in circulation. Rhino no longer use the lock system you are describing (although other manufacturers have since adopted it).
You can tell the difference by looking at the hinges - the first generation has a moulded hinge on the top of the tube, the current model has a pressed steel bulkhead visible with a pivot at each side.
Dosen't matter, I had my Rhino Carrier done over on my drive. The swines sliced open the locking mechanism with an angle grinder/bosch multi tool type of equipment.
Luckily I only ever store overflow or waste pipe in there overnight, so no "booty" call for them hahaha.
the best tube carrier i think is the one that holds a 60 volt lockable control that activates when you lock the van....................... i just cat seem to find one yet LOL
Thanks Rhino Tech Team - It sounds like the new version stops/limits the casual thief. Harder to stop someone armed with an angle grider on any pipe rack! Still struggling in the back of the van at the moment.
if you can engineer an exploding dye device much like thoses used in security vans to sit in the end of your tubes then i will by 2 for sure! ;)
We use 4" diy carriers on our vans, we also try not to keep LOADS of copper in them just two lenghts of 15, 22 and maybe one length of 28 as van stock. If we need any more than that we'll buy it as we use it and we don't lock the carriers as it just looks like there's something valuable in there. In over ten years on our estate in the north east, we've had precisiely ZERO break-ins...
i use the inside of my van, its got an alarm and anti smash and grab glass, its pretty good at carring pipe
Let's be honest if they want to pinch it they'll pinch it! might as well make it so there's as little damage to your van as possible.
or pepper spray, or a large inflatable boxing glove lol filled with metal pellets
As someone who was done for the second time 2nights ago on my drive, i agree that the exploding dye is a great idea as long as the dye is laced with drain cleaner. Mine had locks on but no longer will i carry any tube in it, just plastic and with no locks. God forbid i catch these scroats !
i use 240v from the mains connected via car jump leads its effective but my cd player in teh van keeps catching on fire
You're meant to plug it on to the tube carrier, not the cd player ... DOH!!!
:sweatdrop:
Latest plan: I'm looking at putting in some low bids on Flea Bay for some cheap used pipe carriers, which will be less than the materials for a DIY carrier. Lets see if its enough to get one. Similar to some of you a few 15/22 lengths in the van is enough most the time, but will be nice to have the room for more pipe now I'm getting a few boiler jobs. Most the time I'll probably leave it unlocked and just for plastic/empty. But no fun carrying pipe in and out of the house when raining at the end of each day, so will come in handy then.
I've used soil pipe on roof bars for several years with unlocked screw cap at rear. Had van broken into twice. First time they took copper and barass pipe fittings from inside van, the second time they opened glove box but took nothing. ( probably after a sat nav.) Neither time was the 'pipe carrier' opened!
I wonder if that's because you smeared a Mars bar over it to make it look more authentic?
If you do get use soil pipe a top tip is to secure the screw on ends with washing line ( drill through the middle).
I lost loads of em over the years befor I did this.
I have the first generation Rhino tube and indeed the lock are useless.
With the filth on our streets at the moment I have to cut all my copper up and keep it in the van.
Well I'll only purchase a naff product the once, I think I paid around ÂŁ250-ÂŁ300 even 5 years ago for a pair. After losing, well I didn't lose it, it was stolen over ÂŁ600 of copper, calling Rhino's customer service about the poor locking mechanism with little satisfaction. I personally would not buy from them again. I don't expect it to bother them as the purchase is a one off maybe every 4 or 5 years when the van gets renewed. I'm not bothered whether there's 2nd 3rd or any other kind of generation on the market now, I bought in good faith a product from them, that was marketed as being tough, secure and robust. It was not and it was sold / purchased not fit for it's purpose.
I carry my copper in square gutter down pipes screwed to the inside of the van. It's secure and keeps the cost of fuel down.
I made my new van a MWB van so I could store them inside alongwith the ladders. All racked away and by not having the rack, ladder and pipe carriers on the roof the fuel cost is cheaper than my old SWB van.
Don't know how much of that is down to the vans being different makes/models though.
Reply to Best pipe tube carriers - how thief proof are they? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
  • Locked
Hi, We've recently bought a house and I've only just noticed that the gas main running from the meter is lead for a few metres and then joins...
Dotty
A
  • Locked
Repost as I was told to register: Hi, We've recently bought a house and I've only just noticed that the gas main running from the meter is lead...
6K
A
M
  • Locked
What pipe carriers do people have on their vans, and would you recommend what you've got? I decided not to have an aluminium tube like Rhino...
K
  • Locked
Hey guys Looking for a pipe tube rack for copper tube and/or waste pipe lengths (3m) Has to be secure and lockable! My van is a 2008 ford transit...
Koogatubac
K
E
  • Locked
Went to look at a flue on a duotec he this evening for a forum member brd bri, original post was something like is the is a standard Baxi flue...
