Discuss 18mm plastic pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
migoplumber
hi, just been called to a leak at a school in blackpool, joiner chopped through under floor heating pipe.
usually not a problem, however this turns out to be 18mm.
been on the web and can order from australia, but does anyone know anywhere in england that deals with weirdo sizes
thanks for help.
shaun
07835192578
hey matey, polypipe do an 18mm underfloor heating pipe. so you should be able to get it here.
heres a link to their web
[DLMURL="http://www.polypipe.com/polypipe/controller?action=BP-Products&categoryID=306"]Polypipe Products | Specialist Underfloor Heating Pipes | Polypipe[/DLMURL]
Thanks nick, site looks promising, cant actually find the fittings, but if they sell the pipe im sure they can at least provide some help. I'll ring them monday. thanks again.
shaun
Right, typical plumbers life.
polypipe uk sells 18mm pipe. you can buy miles of the stuff as much as you like, to the moon and back, brilliant.
polypipe uk has no means of joining the pipe to anything or providing you with the simplest insert so that even if you had a fitting, you could use it!!
I am ordering from australia. dont forget I only need 30cm of pipe, but yes as normal i am ordering 100 metres of 18mm pipe (smallest possible order) and 25 18mm couplings plus 100 inserts!!
so if any of you plumbers out there need any, let me know, i will have loads and god its expensive.
shaun
You can get any size of any fitting for instance from Poland. Much quicker, much chepar and much better choice than from Australia. Germans offer similar range of products.
Reply to 18mm plastic pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
Hi guys, first post here So I have been boxing in a number of heating pipes that are throughout my garage since the boiler was located there by the previous owner, they decided to run pipes all along the edge of the garage floor... I do however have one that goes vertically out of the concrete...
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need to tell you about my system, and the problem I’ve been having. Just over 7years ago I had a new CH system installed in my small semi. I say new – in...
Hello all. I've just joined, was going to post in the new members forum, but the first site generated email sent me here... I am here, as have a challenging and interesting problem, which I'll try as best to describe below keeping to the point and as short as possible, to avoid boring any of...
3K
Hi, I would appreciate your opinion on this. Our heat pump broke down while we were away and the temperature in the house dropped. A plumber came out to look over the house and check for damage. A couple of taps broke but we had turned off the water so no major problems that cant be fixed...
1K
