Discuss What is correct toilet supply line in the USA area at PlumbersForums.net
It reminds me of a washing machine hose which is 3/4". Could it be the same size as that? It's hard to get the scale from the picture.
Reply to What is correct toilet supply line in the USA area at PlumbersForums.net
Hi there, can anybody help? I am trying to buy a replacement toilet flush push button as my current one is broken? However I cannot find the same...
Hi there. I have a Cersanit close coupled toilet which as started leaking between the cistern and the bowl when flushed. I've taken the cistern...
Hi all, apologies in advance for my ignorance. I have an old style toilet with what I've researched is a ballcock. The toilet was screaming every...
Hi I have a 22mm hot and cold water supply to new bath. The pipes finish with compression valves. I need a 500 mm tap connector hose to connect...
R
Hi there, Please excuse my lack of knowledge on this, my plumbing knowledge is very limited. I have a cold water feed going into cistern with...
