Discuss 1 Rad only working with pump on full in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hope someone could give me some advice.
I have 1 radiator in the house in the front room (largest one in the house) which will only heat up when I have the central heating pump turned up to full power.
All others work fine on medium or eco mode. The one not working is stone cold even at the inlet pipe unless the pump is turned right up.
What could be causing this? We have recently had a brand new pump fitted.
Thanks in advance
Why was a new pump fitted?
What make/model was the old pump?
What make/model is the new pump?
Does the problem rad get hot, at normal speed, if other rads are turned off?
Have you checked if both of the pump valves are full open?
Does the radiator have lockshield and a thermostatic valve and are they open? TRVs can seize.
Also it is possible to have a faulty new pump with these new A rated tat, so don't rule out the pump just because it is brand new
Reply to 1 Rad only working with pump on full in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The existing pump flows downwards. The manual for the proposed replacement recommends that it should pump upwards. This would involve rearranging the flow &...
Hi, I am currently using a Grundfos Booster Pump. This pump is fed by 2pcs of 1,000 liters water tank. Normally the pump would stop working only when there is no water in the water tank. But, recently for the past week, in the middle of the night, the pump would stop working even though the...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always amazed at the water pressure so on the odd occasion that the water was only luke warm it was easily forgiven, but over time we have come to realise that...
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the AUTO (adaptive mode) setting on this the new pump or which mode it is best set at (recently had our old 3-speed pump replaced with the above smart...
Hi there, I’m hoping someone can help me with this problem please. I’ve searched for similar posts but not found anything helpful! My mum’s house has a pump which pulses on and off every time a tap is opened. Even filling the bath (pressure is strong) the pump won’t come on and stay on but...
