Discuss 1/2 BSP to 15mm compression adaptor, Mirror Chrome in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. bumbulum
    bumbulum New Member
    Morning all!
    I am trying to find the above adaptor with no success so far. Plenty available in non-mirror chrome but that'll look bad between mirror chrome thermostatic tap unit and similar shower riser. (I'm fitting a rigid riser to a Bristan tap unit threaded with a male 1/2 in outlet for a shower hose.)
    Any pointers much appreciated.
  2. ShaunCorbs
  3. bumbulum
    bumbulum New Member
    Thanks Shaun, the tap has a male outlet so I am looking for a female adaptor, and preferably in mirror chrome as opposed to a light chromed rough-finished plumbing connector.
  4. ShaunCorbs
    Thought you might I added a second link
Loading...
Similar Threads - 15mm compression adaptor Forum Date
Upgrade from 15mm to 22mm worthwhile? Fittings & Pipes Jan 19, 2018
Request for help to source 14 to 15mm pipe connector / reducer / joint please. Fittings & Pipes Jan 18, 2018
