Chatrooms
electric shower -
Go Back   Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK > Plumbing Forums > Showers and Wetrooms
Notices
Old 4 Weeks Ago   #1 (permalink)
pauls
Info
Default electric shower
im sure this has been asked before but i cant find it..........
a straight swop for old to new electric shower do i need a sparky
pauls is offline
Old 4 Weeks Ago   #2 (permalink)
secret squirrel
Info
Default Re: electric shower
No, providing swapping like for like. Be very careful if your increasing the KW of the shower though.......
secret squirrel is offline
Old 4 Weeks Ago   #3 (permalink)
dontknowitall
Info
No need if you know what you're doing. When I fit a replacement (especially a higher wattage) I always phone a friend.
dontknowitall is offline
Old 4 Weeks Ago   #4 (permalink)
pauls
Info
its an old shower so not sure of the kw, the new one is 8.5kw
pauls is offline
Old 4 Weeks Ago   #5 (permalink)
secret squirrel
Info
6mm cable into a double pole isolator, then a 30amp mcb (think its mcb, must trip out), depending on the cable runs etc but I'd need to look it all up....
Old 4 Weeks Ago   #6 (permalink)
dontknowitall
Info
There was me thinking it had to be 10mm (but maybe not for that size shower)! This is why I phone my sparky friend and get him to change things if necessary.
Old 4 Weeks Ago   #7 (permalink)
secret squirrel
Info
I don't think so, but then you do need to consider length of runs etc if its over a certain length (again need to check) its 10mm. If I have a doubt I check with my sparks as well..... just in case.
Old 4 Weeks Ago   #8 (permalink)
pauls
Info
can the fuse at the mcb give me an idea of the kw
pauls is offline
Old 4 Weeks Ago   #9 (permalink)
secret squirrel
Info
Its 30 amps, to be sure you'll find it in the instructions for the shower mate. If it is above 8.9kw then it jumps considerably to (don't quote me) 45.
Old 4 Weeks Ago   #10 (permalink)
oldplumber
Info
Quote:
Call an electrician you are starting to sound like jambo!!!
you need a sparky as all new showers must have and rcd or rccb fitted to stop the customer dancing hard when they go live due to water getting into your electrical work. All the fuse (not reccommended now) or mcb does is protect the wiring from overheating and causing a fire.
The cable rating depends on both the length of run and wattage of shower. Unless your qualified in electrics dont mess with it, its what we all harp on about with gas work, so follow our own example, and if youre not competent as in niceic quals/registration your insuruers wont cover you when your customer gets a h**d on due to your cock ups with their wiring.
oldplumber is offline
Another Mira shower problem davemazo Showers and Wetrooms 8 17-01-2010 02:24 PM
electric shower with hot water tap feed ? scooter Plumbing Forum 3 05-12-2009 01:57 PM
Pipe CHASING electric shower bureaucrazy Showers and Wetrooms 10 08-04-2009 10:06 PM
Electric Shower Problem / How to fix? Tiv Showers and Wetrooms 2 27-03-2009 08:56 PM
PRV on electric shower?? Tosh Plumbing Forum 2 27-02-2009 10:34 AM
