Go Back   Plumbing Forum | Plumbers Forums | A forum for plumbers in the UK > Plumbing Forums > Showers and Wetrooms
Showers and Wetrooms Discuss all aspects of plumbing and installing showers and creating wetrooms in this forum.
Old 26-09-2007   #1 (permalink)
Matty A
View Matty A's Photo Album
Default Electric shower problem
Hi guys/gals
Fitted a new electric shower today and when i turned the water back on to test for leaks everything was fine untill i turned the cold tap on at the bath and when i turned it off again water came out of the shower head
I must add that the system the house runs on is gravity fed and the tank is in the cupboard in the bedroom opposite making it about the same height as the shower, now i was thinking that it is a pressure problem in that the pressure is too low when the taps are turned on at any time causing the shower valve to open.
If this is the case how do i increase the pressure? Would it work if the exp' tank was moved into the loft which would make it about 4-5ft higher than it is now or can i buy a little pump of sort to go onto the pipe that is supplying the shower?
Cheers
Mat
Old 27-09-2007   #2 (permalink)
uug197h
View uug197h's Photo Album
Default Re: Electric shower problem
the norm for an electric shower is 1 meter head of water IE: the tank should 1 meter above the shower, you can not fit a pump with the electric shower, you can put in a feed from the main supply ( the cold water feed will be a main supply for 1 tap (first one in near the shutoff valve) and the feed to the tank) this would be mains pressure and should ok, do not feed from a bath tap supply
Old 02-10-2007   #3 (permalink)
Matty A
Cheers for reply mate,
Sorted the problem with a one way check valve.
bathstore.com victorian shower problem paul70 Showers and Wetrooms 1 1 Week Ago 12:28 AM
Shower hot water problem deaddraw Plumbing Forum 5 3 Weeks Ago 10:53 PM
Electric Shower PRD leuven Plumbing Forum 1 20-10-2008 09:16 AM
Architeckt Avus shower temperature problem fat_wookie Showers and Wetrooms 4 25-09-2008 04:31 PM
How high should I put my electric shower? cacran Showers and Wetrooms 2 27-08-2008 03:18 PM
