Quote:
Originally Posted by ajs heating
the thermostatic cartridge should be ok. it takes more than that to knacker them.
try the valve first thats what i would opt for then we'll go from there.
Right then, I've checked the valves that you mentioned and they all seem fine. I also re-set the temperature gage so it should go to a higher temp than before. The shower is now all back together.
HOWEVER I've now noticed something else which may help towards diagnosing the problem.
When I turn the shower on a tiny bit (literally the least powerful it can go) the temp is fine and hot water is coming through as normal however when I turn the power knob up to the type of speed you would normally shower at and above, the heat dissappears, the water just goes cold and the boiler goes off.
Would this suggest that the cold water pressure is too high and is over-riding the hot? Meaning I need to get a PRV fitted??? EDIT - although that wouldn't explain why when the pipes were the wrong way round, the water was coming out scalding hot.
My head hurts!
