Go Back   Plumbing Forum | Plumbers Forums | A forum for plumbers in the UK > Plumbing Forums > Sanitary Ware
Sanitary Ware Subjects related to sanitary ware are in this forum.
Old 11-08-2008   #1 (permalink)
claystiles
View claystiles's Photo Album
Default water is coming up plug hole!
a relly of mine rang me the other day & said when they run the taps in the basin the bath plug hole brings up water!
i thought the pipes was blocked so we cleaned them out now he's rang earlier to say its worse since we cleaned out pipes!
have i missed something really obvious?? i did notice the bath tub is low to ground,possible the pipes not high enuff off ground???
CLAY'S TILES
Telford
07932562458
claystiles is offline   Reply With Quote
Old 11-08-2008   #2 (permalink)
uug197h
View uug197h's Photo Album
Default Re: water is coming up plug hole!
the two pipes are linked and i think you will find the water is trying to flow up to the out side pipe causing it to back flow in to the bath re-do the pipes with the correct fall and you should solve the problem
Plumbing Forum Moderator
Old 11-08-2008   #3 (permalink)
claystiles
Quote:
if the bath cannot be highered up to give me clearance wot would be best option??
possible to run under floor boards if he's not got floor tiled!
does that sound right??
CLAY'S TILES
Telford
07932562458
Old 11-08-2008   #4 (permalink)
uug197h
Yes if there floor boards you may be able to run the pipes under them that would be the best option
Old 11-08-2008   #5 (permalink)
claystiles
thanks m8!
CLAY'S TILES
Telford
07932562458
Old 11-08-2008   #6 (permalink)
DB-Tiling
View DB-Tiling's Photo Album
how long has the set up been running for without a problem?
if its just started recently then there must be a blockage or fault?
DB-Tiling is offline   Reply With Quote
Old 12-08-2008   #7 (permalink)
claystiles
the bathroom was put in over year ago, problem only started last few months!
CLAY'S TILES
Telford
07932562458
Old 15-08-2008   #8 (permalink)
fuzzy
View fuzzy's Photo Album
blockage, try to take the pipes out to investigate
Old 15-08-2008   #9 (permalink)
claystiles
good news! the pipes was cleaned out,but there was a blockage towards the waste, the lady of house blasted bleach down the pipes & hey presto nice clean pipes,blockage free!
thanks for your help boys!
CLAY'S TILES
Telford
07932562458
Old 15-08-2008   #10 (permalink)
DB-Tiling
glad to see you got it sorted without ripping the floor boards up.
see uug, its not always the hard way
Dont let the saloon doors hit you in the ass on the way out!
Advice require - Electric Water Heater / Old Gas Boiler salbal77 Plumbing Forum 0 12-10-2008 07:18 PM
water tank overflows not ball cock or split coil in cylinder dannyabb Central Heating Forum 14 25-08-2008 10:11 AM
Open Question: Water is seeping out of an air valvue on our hot water plumbing? RSS Feeder Plumbing Questions 0 25-08-2008 09:30 AM
HELP! - WARM/HOT water coming from the COLD tap? 34mark@gmail.co Plumbing Forum 3 19-07-2008 11:55 AM
