Results 1 to 4 of 4
Plumbing & Plumbers Forum - Flush pipe length.
Like Tree3Likes
  • 3 Post By Last Plumber
Flush pipe length.
Discuss Flush pipe length. at UK Plumbers Forums; Hi all. I've installed a low level WC which is not so low level. The manufacturer's instructions say that the cistern should be 1m above the floor, and it's provided ...
    Jan 2015
    Cardiff
    Default Flush pipe length.
    Hi all.
    I've installed a low level WC which is not so low level. The manufacturer's instructions say that the cistern should be 1m above the floor, and it's provided with a flush pipe which sets it at 90cm. I am unhappy with the look as it seems too high but reluctant to cut the flush pipe as it is chrome.
    It comes from Bathstore.
    There is also another WC in the property which came from the same place which has a shorter flush pipe. Could anyone tell me is there a minimum length for the flush pipe.
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,441
    Default Re: Flush pipe length.
    Pipe it up in plastic at the length you like and flush a wad of loo roll down, see if it works !
    Best, Masood and smudgie56 like this.
    N.Ireland, United Kingdom
    6,994
    I agree with doing a temporary pipe up with plastic flush pipe and cistern on a support to test if flush is good with plenty loo paper in pan.
    Jan 2015
    Cardiff
    Thanks for the advise. I will try it.
  1. What's The Minimum Length Of Pipe I Need To Get A Freeze Kit On?
    By plumbandplumber in forum Plumbing Forum
    Last Post: 06-10-2016, 08:47 PM
  2. Need a short length of 10mm HEP2O pipe.
    By MickBrown in forum Central Heating Forum
    Last Post: 28-01-2013, 07:04 PM
  3. Replies: 3
    Last Post: 23-06-2012, 07:28 AM
  4. Pipe bend raduis and length
    By James O'Donnell in forum Fittings & Pipes
    Last Post: 06-02-2011, 07:13 PM
  5. 40mm pipe length
    By old diyer in forum Plumbing Forum
    Last Post: 17-11-2009, 11:37 PM
