Results 1 to 6 of 6
Plumbing & Plumbers Forum - 3 inch lead soil pipe
Like Tree4Likes
  • 2 Post By joni os
  • 1 Post By jtsplumbing
  • 1 Post By Last Plumber
Discuss 3 inch lead soil pipe at UK Plumbers Forums; hi my current toilet has been in for over 30 years and is connected to a 3 inch (83mm) lead pipe which goes straight through the wall to the cast ...
    Jan 2017
    Default 3 inch lead soil pipe
    hi
    my current toilet has been in for over 30 years and is connected to a 3 inch (83mm) lead pipe which goes straight through the wall to the cast iron pipe. The centre line of this lead pipe is also around 80mm from floor level whereas the centre-line of the 4" (102mm) outlet on the new toilet is 180mm from floor level.
    What are my options please?
    thanks
    Mar 2013
    1,340
    Default Re: 3 inch lead soil pipe
    Replace all or part of cast pipe with plastic. Branch off and come through wall at required height in 100mm.
    Masood and Last Plumber like this.
  3. The Following User Says Thank You to joni os For This Useful Post:
    jtsplumbing's Avatar
    Tavistock. Devon
    4,764
    Time to get the cast cutter out,
    Last Plumber likes this.
  5. The Following User Says Thank You to jtsplumbing For This Useful Post:
  6. #4
    Chalked's Avatar
    3,814
    The lead should come out of the tee in the soil pipe. You can then put in a cast yo plastic adaptor, and replace with plastic to the correct height.
  7. The Following User Says Thank You to Chalked For This Useful Post:
  8. #5
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,127
    I would recommend as above. Replace the soil pipe. Proper job !
    jtsplumbing likes this.
  9. The Following User Says Thank You to Last Plumber For This Useful Post:
  10. #6
    Jan 2017
    In the end i took the rubber grommet thing off the outlet of a flexi pipe leaving the plastic only which had an internal diameter of about 85mm, so i stikaflexed this to the 83mm OD lead pipe, so far so good only had one blockage (to be expected with expecting 4" of waste into 3"), not perfect but i'm selling the house so wanted to do it as cheap as poss...
    thanks
  11. The Following User Says Thank You to brian32128 For This Useful Post:
  1. Replies: 2
    Last Post: 06-06-2015, 01:07 AM
  2. Unused 6 inch cast iron soil pipe
    By Jim85 in forum Plumbing Forum
    Last Post: 26-11-2014, 10:36 PM
  3. Connection for lead soil pipe please
    Last Post: 01-09-2012, 05:30 PM
  4. Tee into a 3.5 inch Copper soil pipe
    By ksareen in forum Plumbing Forum
    Last Post: 16-07-2012, 05:23 PM
  5. lead soil pipe from WC to CI stack
    By mjt in forum Plumbing Forum
    Last Post: 15-09-2010, 05:06 PM
