Plumbing & Plumbers Forum - Toilet pan connection problem
Discuss Toilet pan connection problem at UK Plumbers Forums; I need to connect a WC to a horizontal soil pipe - the problem is that the centres are only 150mm apart from where the pipe enters the floor. I ...
    kc1
    kc1 is offline
    Sep 2012
    Default Toilet pan connection problem
    I need to connect a WC to a horizontal soil pipe - the problem is that the centres are only 150mm apart from where the pipe enters the floor. I also need to connect the basin waste somewhere.
    This connection is within a cabinet behind the WC, so have about 300mm depth to play with too - the pipes are close to the wall.
    I have 2 possible ideas :
    1. use a solvent weld T horizontally, and an elbow - but trim each socket down to about 20mm before gluing a 40mm bit of pipe between.
    2. bring the existing soil pipe in higher up the wall completely above the WC connection, and then use a branch at the bottom mounted 45 degrees round (forward), with another 45 degree bend connecting to the WC. I think rotating 45 degrees will give me about 210mm between centres (if i've got my maths right).
    Which would be better - or is there an entirely different way to do this?
    I also need to find some way to connect the basin waste pipe - does anyone make a 90 degree 110mm bend with a boss for a 40mm pipe? - i can't find one anywhere.
    Mar 2012
    Bolton
    2,097
    Default Re: Toilet pan connection problem
    Don't think I've seen a 90 bend with boss, there are pan connectors with a boss, or use a strap boss.
    Mar 2008
    513
    I think I'd cut the soil pipe above the floor, fit a branch vertically above that and then use a 110 street elbow to connect the WC. You can cut the spigot on the street elbow to get it close to the stack. Hope that makes sense.
  1. Toilet connection
    By Dparker357 in forum Plumbing Forum
    Last Post: 02-10-2016, 11:21 AM
  2. Iron Toilet pan connection
    By kirby85 in forum Plumbing Forum
    Last Post: 10-11-2015, 07:37 PM
  3. Toilet leaking from cistern connection.
    By stuco in forum Sanitary Ware
    Last Post: 17-01-2011, 09:12 PM
  4. toilet cistern inlet connection
    By andekoch in forum Fittings & Pipes
    Last Post: 18-04-2010, 11:46 PM
  5. Toilet Waste Connection problem
    By Ruairi in forum Sanitary Ware
    Last Post: 26-01-2010, 01:21 AM
