Results 1 to 12 of 17
Plumbing & Plumbers Forum - WC Flush pipe moving!
Discuss WC Flush pipe moving! at UK Plumbers Forums; I have a client with a back to wall pan and concealed cistern. The flush pipe keeps working its way out of the pan. I've replaced the flush cone, but ...
    Nov 2014
    Default WC Flush pipe moving!
    I have a client with a back to wall pan and concealed cistern. The flush pipe keeps working its way out of the pan. I've replaced the flush cone, but still no joy. Any suggestions?
    Paulplumb's Avatar
    Aug 2010
    Worcester
    888
    Default Re: WC Flush pipe moving!
    Make sure the cistern has a good solid support the whole depth of the cistern. A lot of times I find the cisterns are just hung on the carcass brace bar and the weight of the water at the bottom the the cistern pulls the cistern back I find.
    10,219
    put a clip on the flush pipe to the wall if you can
    rubber lined clip
    threaded rod
    backplate
    Oct 2016
    12
    Clip flush pipe and silicon. Cone and let it set, there are different cones plastic and rubber
    May 2010
    5,222
    I use the nylon cones personally and I rough up the inside where the cone sits with some coarse emery cloth to give it a key to help prevent it sliding out you may have to fit a small block of wood behind the flush pipe to stop it from moving and clip the pipe to the block hope you get sorted...regards Turnpin...oh and welcome to the forums Alan
    Nov 2014
    Thanks for the advice...reading similar threads, I notice that many recommend a rubber cone/seal, rather than a plastic version. Both the original and the replacement are both plastic.
    Maybe it's a combination of the pipe moving and the seal not gripping?
    10,219
    Quote Originally Posted by Alina View Post
    naughty never use silicon on them
    10,219
    Quote Originally Posted by Alanr147 View Post
    or cheap pan out of spec flush pipe hole (slightly bigger)
    Oct 2016
    12
    If flush pipe is pulling out of flush cone, use a little clear silicon on flush pipe asa it enters cone, no prob and makes a good seal , the amount of flush pipes that weep from cone,
    Nov 2014
    It's more the cone slipping out of the pan I think
    Oct 2016
    12
    Use lsx fernox leak sealer to bed cone in, put it on the fins , don't use to much and do not put it on the first fin that enters pan , let it set , and job done that should solve it ,
    Member PriestyUK's Avatar
    Feb 2013
    Poole, DORSET
    221
    I would say the flush pipe has been cut too short and is pulling back to be honest, if its the cone slipping out try applying some plumbers mate into the groves and inserting the flush cone.
  1. Moving soil pipe.
    By Steveuk in forum Plumbing Forum
    Last Post: 14-10-2016, 11:30 AM
  2. Need soil pipe moving outside
    By Grale in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 13-10-2016, 07:57 PM
  3. Fluidmaster 550 UK dual flush valve to 35mm flush pipe
    By chrisdonne in forum Sanitary Ware
    Last Post: 04-04-2015, 09:48 PM
  4. Flush pipe leak after flush
    By GezDixon in forum Bathrooms, Showers and Wetrooms
    Last Post: 14-04-2013, 09:16 PM
