Results 1 to 6 of 6
Plumbing & Plumbers Forum - Part time flush
Like Tree2Likes
  • 1 Post By ShaunCorbs
  • 1 Post By Riley
Part time flush
Discuss Part time flush at UK Plumbers Forums; Hi all Our cistern has decided not to refill around one in three times having previously stuck maybe one in ten. To make it fill I just have to jog ...
    Oct 2016
    Default Part time flush
    Hi all
    To make it fill I just have to jog the thin plastic serrated shaft on the left (seepicture) This jogs the whole
    mechanism on the left and it immediately fills up.
    I'm thinking of replacing the whole thing but can't see an exact same thing anywhere. It needs to match up with the two push buttons to keep the same lid
    any recommendations would be gratefully viewed
    thanks
    Peter
    9,673
    Default Re: Part time flush
    Change the lot for a fluid master flush kit if you can get the one with a brass tail on the full valve / inlet valve
    Stigster likes this.
    Riley's Avatar
    Sarf Coast
    6,387
    Does the flush part work if so then keep that as that will still work with the button you have then as above just replace the filler with a fluid master. Again as above if the flush doesn't work then replace the lot for a fluid master flush kit
    Chalked's Avatar
    3,814
    Looks like it's catching on the side of the cystern.
    Will just need turning slightly so it has free movement.
    1Steven's Avatar
    Jun 2015
    Lincolnshire
    548
    Oct 2016
    Thanks for all the quick replies. I've made a note of the replacement but so far, having turned the blue part a bit anti clockwise it seems to be fine
  1. Northampton part time/ full time work wanted
    By calinfila in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 16-09-2014, 10:40 PM
  2. Part time plumbing
    By london2345 in forum General Off-Topic Chat
    Last Post: 01-09-2013, 06:49 AM
  3. Part Time apprentice?! How are you going about it?
    By Aismail in forum Plumbing Courses
    Last Post: 26-07-2011, 01:39 PM
  4. what do you think to this, part time course
    By clio182 in forum Plumbing Forum
    Last Post: 23-03-2011, 08:32 PM
