Plumbing & Plumbers Forum - Any ideas of how to remove the nut on a high level WC cistern
Like Tree2Likes
  • 1 Post By Fallon1982
  • 1 Post By Paul Cockhill
Discuss Any ideas of how to remove the nut on a high level WC cistern at UK Plumbers Forums; Hi I have been unsuccessfully trying to remove this nut to release the syphon from a high level cistern. The pipe is plastic so I cannot heat up the nut. ...
    Apr 2009
    219
    Default Any ideas of how to remove the nut on a high level WC cistern
    Hi
    I have been unsuccessfully trying to remove this nut to release the syphon from a high level cistern. The pipe is plastic so I cannot heat up the nut. I have tried freeze it spray which usually works but not on this occasion.
    Any ideas?Any ideas of how to remove the nut on a high level  WC cistern-2016-09-27-16.38.02.jpgAny ideas of how to remove the nut on a high level  WC cistern-2016-09-27-16.38.10.jpgClick image for larger version.
Name:	2016-09-27 16.38.02.jpg
ID:	27454Click image for larger version.
Name:	2016-09-27 16.38.10.jpg
    Feb 2015
    Wokingham
    176
    Default Re: Any ideas of how to remove the nut on a high level WC cistern
    Try a hair dryer to warm it?
  3. The Following User Says Thank You to Stoney Ground For This Useful Post:
    Oct 2013
    West Sussex
    3,387
    get a pair of grips on the threaded part and a decent adjustable spanner on the nut, should come off with no problem!
    Just don't mangle the thread up.
    I'm easily confused so speak very very slowly
  5. The Following User Says Thank You to Ch4 plumbing For This Useful Post:
  6. #4
    N.Ireland, United Kingdom
    6,918
    As above, ^^ just use large adjustable or grips on the nut and hold the top of syphon with your other hand to prevent it turning. Only use grips on threads as last resort and don't let them slip on the threads and damage them badly.
    12 inch Footprints are great grips
  7. The Following User Says Thank You to Best For This Useful Post:
  8. #5
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,127
    Morning, is that not an
    old Bakelite cistern ?
    I know this may cause alarm unnecessarily and I don't mean to because it's extremely unlikely any thing might happen but Bakelite sometimes had asbestos mixed in with it for strength.
    It's unlikely you will scratch damage or crack it but please be careful with it !
    my apologies if it's plastic
  9. The Following User Says Thank You to Last Plumber For This Useful Post:
  10. #6
    242
    I think Last Plumber is right. I think them cisterns do have an element of asbestos in them. We used to have to get a licensed asbestos removal company in to remove them when I was working for a local council.
    We was always told not to disturb them - just replace the cistern. I think in reality I would recommend, that if you have to put too much pressure on breaking the nut, quote for a new cistern. Dudley do a rubber well at most suppliers.
    Last Plumber likes this.
    Visit our website at - www.cjf-plumbing.co.uk
  11. The Following User Says Thank You to Fallon1982 For This Useful Post:
  12. #7
    Apr 2009
    219
    Hi Everyone
    Many thanks for your replies. The WC has been there a long time, it is probably bakelite. I did manage to break the nut seal with two extendable spanners and "Crack it" spray. Fitted a Dudley 88 syphon easily in its place.
    Paul
    turnpin likes this.
  13. The Following User Says Thank You to Paul Cockhill For This Useful Post:
  1. High level cistern question
    By Apim in forum Plumbing Forum
    Last Post: 11-03-2016, 05:51 PM
  2. High level cistern problem
    By Unregistered in forum Sanitary Ware
    Last Post: 11-03-2016, 02:35 PM
  3. High Level Cistern
    By Rusty's_Kitchen in forum Plumbing Forum
    Last Post: 07-11-2014, 10:46 PM
  4. High level to low level cistern
    By nealbyuk in forum Plumbing Forum
    Last Post: 07-07-2010, 02:13 PM
  5. High Level Cistern
    By les luchini in forum Plumbing Forum
    Last Post: 31-01-2010, 10:59 AM
