Results 1 to 12 of 16
Plumbing & Plumbers Forum - Phantom toilet flushes....
Discuss Phantom toilet flushes.... at UK Plumbers Forums; Hi all, I wonder if anyone can help? My downstairs loo has started to flush itself 3 or 4 times after each flush. It's obviously overflowing and them somehow rectifying ...
    Oct 2013
    23
    Default Phantom toilet flushes....
    Hi all,
    I wonder if anyone can help? My downstairs loo has started to flush itself 3 or 4 times after each flush. It's obviously overflowing and them somehow rectifying itself but I can't work out how or why this is happening. I've attached a few pics of the inside of the inside of the cistern in case anyone has any ideas of what I should do to troubleshoot.
    Many thanks in advance!
    Bugsy
    Phantom toilet flushes....-img_1983.jpgPhantom toilet flushes....-img_1982.jpgPhantom toilet flushes....-img_1981.jpg
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    8,100
    Default Re: Phantom toilet flushes....
    Water level looks around 10mm high, start with adjusting the part in photo number1 to bring it down to the casting mark in the cistern.
    Oct 2013
    23
    Hi Rpm,
    Many thanks for your response. I have just lowered the white float bit in pic 1 by screwing the grey bit (!). Once flushed the water starts to refill the cistern lifting the white float. When the float can go no higher the water continues to fill the cistern (from the bottom I believe) until a "phantom" flush is triggered because the water level is too high.
    Lowering the white bit caused the flushes to seemingly go on indefinitely. Once I screwed it back to its original position it eventually stopped.
    Hope that makes sense.
    Cheers,
    Bugsy
    rpm
    rpm is offline
    Member rpm's Avatar
    8,100
    Lets see if anyone can suggest a repair kit or how-to-clean solution.
  5. The Following User Says Thank You to rpm For This Useful Post:
    Oct 2013
    23
    Fingers crossed! Unfortunately, since fiddling the cistern has been constantly filling and therefore flushing. I have had to turn off the flow to the downstairs loo and declare it "out of bounds!"
    I fear that this might not be an issue I can rectify myself and will have to get a man in!
    uɐɯ sɐƃ moderator
    gas man's Avatar
    18,754
    Sounds like inlet valve knackered,fit a new one
    Masood likes this.
  8. The Following User Says Thank You to gas man For This Useful Post:
  9. #7
    Oct 2013
    23
    Hi Gasman,
    Thanks for getting back to me. Would fitting a new inlet valve be something be something that I could tackle myself? - I'm a pretty confident DIYer (although not as young as I used to be!). If so, would you be able to point me in the direction of the appropriate part?
    As ever, thanks for your help
    Bugsy
  10. #8
    thereisawizza's Avatar
    May 2010
    Hythe, Kent
    599
    You can repair inlet valve, if you're not to good with the DIY, you can change just the washer to the valve:
    http://www.screwfix.com/p/arctic-pro...m-washer/5006j
    5 min job, worth a shot!
  11. The Following User Says Thank You to thereisawizza For This Useful Post:
  12. #9
    Oct 2013
    23
    Brilliant! Thank you Thereisawizza. I assume the valve is located under the white bit with the grey screw? (sorry for my amateur description!). Would you be able to advise how this would be attached and therefore removed?!
    Many thanks
    Bugsy
  13. #10
    ADMINISTRATOR REDSAW's Avatar
    Jan 2009
    Nottingham
    13,334
    take big white nut off after isolating water supply.
    theres a black washer behind that needs changing, or buy identical and change whole top section is easyist to do if not sure.
    those valves are rubbish, sometimes its the plastic arm at fault and hard to detect!
    ¿ʞɹoʍ sɐƃ
  14. The Following User Says Thank You to REDSAW For This Useful Post:
  15. #11
    Oct 2013
    23
    Hi Redsaw,
    Thanks everso much for your advice. That certainly sounds like something I can attempt in the morning!
    Thanks again,
    Bugsy
  16. #12
    uɐɯ sɐƃ moderator
    gas man's Avatar
    18,754
    if that does not work this will sort it,just make sure the float passes the syphon http://www.screwfix.com/p/fluidmaste...Faky0wodvQ0LNQ
  17. The Following User Says Thank You to gas man For This Useful Post:
  1. Sink and bath wont drain but toilet flushes fine
    By Charlie Louisa in forum Plumbing Forum
    Last Post: 18-07-2015, 03:55 PM
  2. Replies: 7
    Last Post: 25-03-2014, 01:16 PM
  3. Boiler fires up when toilet flushes
    By Aquariusplumb in forum Plumbing Forum
    Last Post: 01-08-2013, 06:14 PM
  4. Shower only hot when toilet flushes!
    By coldshower in forum Plumbing Forum
    Last Post: 18-12-2012, 06:28 PM
  5. toilet flushes slowley
    By homeguy30 in forum Plumbing Forum
    Last Post: 20-02-2011, 06:19 PM
