Plumbing & Plumbers Forum - porcelin leaking?
porcelin leaking?
Discuss porcelin leaking? at UK Plumbers Forums; Hi all, I've been out to fix a leaking toilet this week. It has a low-level cistern, hung on the wall. The customer reported a very very slow leak, coming ...
    Sep 2011
    142
    Default porcelin leaking?
    Hi all,
    The customer reported a very very slow leak, coming through from the flush valve under the cistern, continuing when the toilet wasn't used for any length of time.
    It has a dudley turboboost inside. I've changed the washer, and put the original turboboost back in place. I didn't use sealant or plumbers mait, but - as usually works fine for me - made sure the porcelein was totally dry and clean.
    Two days later, the leak is reportedly continuing.
    On the underneath of the cistern, the area around the flush pipe was damp and discoloured.
    I'm wondering if there is a hairline crack in the cistern, or a burr, etc, where the washer sits.
    I'm tempted to replace the cistern itself.
    What would you all do?
    Thanks for your advice,
    Jennie
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    7,840
    Default Re: porcelin leaking?
    Any chance it`s the water coming out of the fill valve hitting the lid and running down the back of the cistern or it`s one of those cisterns with a stupid U shaped bit cut out of the back up high near the lid and water is leaking out there or it`s purely condensation and it`s running down the back?
    Apr 2008
    West Yorkshire
    3,826
    I hate myself but this if why I assemble with a smear of Clearfix as you can use it in wetness. Stops these annoying calls to say it leaking can you come?
    JOTM winner September 2012
    Riley's Avatar
    Sarf Coast
    6,387
    I've had this before and it turned out to be a hairline crack
  5. The Following User Says Thank You to Riley For This Useful Post:
    Sep 2016
    Central London
    37
    I had one of these once the thing was covered in sealant, at the flush pipe outlet, absolutely caked in silicone, the cistern fixing screws had been overtightened when it was installed and it was the tiniest hairline crack.........good call to replace it
  1. Leaking Tap
    By brunochops in forum Plumbing Forum
    Last Post: 01-09-2014, 08:27 AM
  2. Leaking tap
    By luca in forum Plumbing Forum
    Last Post: 09-02-2014, 06:12 PM
  3. Leaking outside tap
    By Foxtrot Oscar in forum Plumbing Forum
    Last Post: 22-04-2011, 09:30 PM
  4. leaking tap
    By lostatplumbing in forum Valves & Taps
    Last Post: 18-10-2009, 10:35 PM
