Results 1 to 8 of 8
Plumbing & Plumbers Forum - Wall Mounted Pan
  • 1 Post By ShaunCorbs
Wall Mounted Pan
Discuss Wall Mounted Pan at UK Plumbers Forums; Hi All, I have a Gerberit Duofix which I boarded over and tiled. When I attach the pan, should I have anything between the back face of the pan and ...
    Jan 2014
    35
    Default Wall Mounted Pan
    Hi All,
    I have a Gerberit Duofix which I boarded over and tiled. When I attach the pan, should I have anything between the back face of the pan and the tiles? The tiles are pretty flat, but should i have a small bead of silicone, or something else there?
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,585
    Default Re: Wall Mounted Pan
    You could put a small bead around if you like. Run one around after its fitted to for neatness
    10,219
    I think there should be a white sheet of foam between them that came with the Geberit
    Last Plumber likes this.
  4. The Following User Says Thank You to ShaunCorbs For This Useful Post:
    Aug 2016
    Lancashire
    1,585
    That rings a bell !
    Jan 2014
    35
    Ah - nothing in the box with this one.
    SimonG's Avatar
    16,219
    The foams an optional extra. Robbing bar stewards. Not as though the frames are cheap.
  8. The Following User Says Thank You to SimonG For This Useful Post:
  9. #7
    Jan 2014
    35
    Thanks all for your input - I have found one of these Abacus Easiplan Wc Frame Self Adhesive Sound proof Pad EPSP-05-3508 which is a few quid less than the Gerberet one and protects that ceramic to ceramic interface!
    Thanks all for your advice.
  10. #8
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    6,690
    You don't really need anything
  1. Screen not being mounted at 90° to wall.
    By dobbyt in forum Bathrooms, Showers and Wetrooms
    Last Post: 26-07-2016, 04:54 PM
  2. I need help :( - wall mounted tap question
    By xsweetmex in forum Valves & Taps
    Last Post: 10-02-2016, 12:58 AM
  3. Removing wall mounted pan?
    By Thegift in forum Bathrooms, Showers and Wetrooms
    Last Post: 14-06-2014, 12:11 PM
  4. Fixing wall mounted tap...
    By Vicar in forum Plumbing Forum
    Last Post: 04-06-2014, 08:09 AM
  5. Wall mounted wc's
    By lbp plg & htg in forum Sanitary Ware
    Last Post: 21-01-2013, 12:23 AM
