Plumbing & Plumbers Forum - Premier NCR140 Holstein Wall Hung Pan - Question
Discuss Premier NCR140 Holstein Wall Hung Pan - Question at UK Plumbers Forums; Hi, I'm new to this forum ... and not a plumber. I had a wall hung toilet that was fitted 6 months ago and I'm now notice intermittent dripping from ...
    Aug 2016
    Default Premier NCR140 Holstein Wall Hung Pan - Question
    I had a wall hung toilet that was fitted 6 months ago and I'm now notice intermittent dripping from below the pan. On inspection, I see that there is a hole at the base. Is this an overflow outlet?
    I've attached some photo.
    Can anyone tell me what it is for and why it should be leaking 6 months after it was fitted.
    Thanks in advance.
    Ed
    Attached Thumbnails Attached Thumbnails Premier NCR140 Holstein Wall Hung Pan - Question-img_20160830_185243106.jpg   Premier NCR140 Holstein Wall Hung Pan - Question-img_20160830_184950665.jpg   Premier NCR140 Holstein Wall Hung Pan - Question-img_20160830_200228750.jpg   Premier NCR140 Holstein Wall Hung Pan - Question-img_20160830_200158392.jpg   Premier NCR140 Holstein Wall Hung Pan - Question-img_20160830_200238017.jpg
    Last edited by Mitch2002; 30-08-2016 at 08:16 PM. Reason: Adding additional photos
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    7,959
    Default Re: Premier NCR140 Holstein Wall Hung Pan - Question
    Welcome to the forums, hard to see from that shot, can you take another showing more of the pan?
  3. The Following User Says Thank You to rpm For This Useful Post:
    Super Moderator
    steveb's Avatar
    Nov 2007
    hythe hampshire
    12,921
    I would say that it from the casting, the pipe from the cistern or soil connection are more likely to be the cause of the drip imho
    The Turtle Moves
  5. The Following User Says Thank You to steveb For This Useful Post:
  6. #4
    Aug 2016
    It's either the flush pipe or the pan connector leaking... You need to take the pan off and apply silicone sealant on both joints between these to pipes and the pan itself... It is most likely to leak here due to the casting not always being spot on with cheaper toilets.... To take off the pan you will need a 19mm ratchet spanner... And don't press the flush button until it's back on!!!
  7. The Following User Says Thank You to Michaelquigley For This Useful Post:
  8. #5
    rpm
    rpm is offline
    Member rpm's Avatar
    7,959
    Quote Originally Posted by steveb View Post
    I agree but just so curious where that hole actually is in the casting.
  9. #6
    rpm
    rpm is offline
    Member rpm's Avatar
    7,959
    Quote Originally Posted by Michaelquigley View Post
    Some are an Allen key fixing.
  10. #7
    Aug 2016
    I've added a few extra photos.
    Thanks for everyone help - I'll arrange for the pan to be removed
    Cheers
    Ed
  1. Cavity wall and wall hung unit...is it possible?
    By kasjk in forum Plumbing Forum
    Last Post: 08-01-2015, 08:01 PM
  2. Replies: 4
    Last Post: 28-08-2012, 11:25 AM
  3. Replies: 4
    Last Post: 24-01-2011, 09:54 PM
  4. Wall hung pan
    By GreenArmy in forum For Sale & Wanted
    Last Post: 11-09-2009, 11:59 AM
