Plumbing & Plumbers Forum - Geberit 60mm outlet cistern seal help
Discuss Geberit 60mm outlet cistern seal help at UK Plumbers Forums; Hi All, I recently moved into a new house and noticed that there was a large amount of rust in between the toilet and the tank so it was only ...
    Jun 2016
    Default Geberit 60mm outlet cistern seal help
    Hi All, I recently moved into a new house and noticed that there was a large amount of rust in between the toilet and the tank so it was only a matter of time before the toilet would start leaking. The toilet has a dual button flush system manufactured by Geberit. I removed the tank and measured the outelt which was 60mm and off i went to Screwfix and toolstation however both stores only suppied kits suitable for 1.5-2inch outlet which i guess is the standard (trust me to have a larger non standard type.). I was wondering if anyone could help me source the close coupling kit that would come with both the doughnut seal and the pressure plate? I have attached some pics which show the dimensions of the current equipment.
    Any help would be appreciated immensely otherwise it's a new toilet lol.
    Attached Thumbnails Attached Thumbnails Geberit 60mm outlet cistern seal help-image.jpg   Geberit 60mm outlet cistern seal help-image.jpg
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    7,840
    Default Re: Geberit 60mm outlet cistern seal help
    Jun 2016
    Thanks rpm.
    Being a novice I am not 100% sure if i have the correct kit picture attached. It says its 2inch in the title but the plate has a 60mm hole which should fit around my outlet and then hopefully the seal would fit. As you will see from the picture though the seal currently installed is approx 70mm internal diamter and with that kit saying 2inch it makes me think its not correct??
    Jun 2016
    I may have to but the kit for the plate with 60m hole and then this seal on top i guess??
    rpm
    rpm is offline
    Member rpm's Avatar
    7,840
    The site was to help you get started and 2" is 2"BSP (British pipe size) which measures 2.347 o/d. Don`t forget the thickness of the washer and either rubber or foam.
    Jun 2016
    Thanks so 2 inch BSP will likely fit but the seal the kit comes with is foam and current installed is rubber so I'm guessing it's just best to order both parts anyway (considering rubber seal is £2)
    9,683
    Quote Originally Posted by Ajack248 View Post
    yes and if your stuck you could always file the plate if its a mm or two out
  1. Help Geberit Flush Pipe & Seal Removal
    By jsm in forum Fittings & Pipes
    Last Post: 16-02-2016, 09:50 PM
  2. geberit flush pipe seal & washer removal
    By Unregistered in forum Fittings & Pipes
    Last Post: 15-02-2016, 09:27 PM
  3. Geberit cocnealed cistern - how to install
    By mo7 in forum Bathrooms, Showers and Wetrooms
    Last Post: 11-08-2015, 09:45 PM
  4. Fan outlet seal on potterton suprima 50l
    By Daz123 in forum Central Heating Forum
    Last Post: 08-09-2013, 12:13 PM
