Results 1 to 2 of 2
Plumbing & Plumbers Forum - maintenance access to flush valve
Discuss maintenance access to flush valve at UK Plumbers Forums; hello, does anyone look after one of the above for a regular customer? The bathroom fitter has jammed the cistern so close to the underside of the vanity worktop in ...
    116
    Default maintenance access to flush valve
    underside of the vanity worktop in this ensuite that I can't even look in let alone unscrew the valve
    from the bayonet. Did anyone get away with cutting an access hatch in the lovely fake marble.
    Valve's chalked up again on the seal. Last time I did it the whole wc had to come out ,cistern snagged
    by flush pipe, that by pan.Thanks,Dean.
    Masood's Avatar
    East London / Essex border
    4,833
    Default Re: maintenance access to flush valve
    If you need to cut a hatch then that's what you need to do! No way round it. I explain what's needed, what the risks are (broken tiles etc) and if possible, make a removable panel held on with mirror screws.
    Find us at:
  3. The Following User Says Thank You to Masood For This Useful Post:
  1. Flush valve
    Last Post: 15-03-2016, 10:10 PM
  2. Fluidmaster 550 UK dual flush valve to 35mm flush pipe
    By chrisdonne in forum Sanitary Ware
    Last Post: 04-04-2015, 09:48 PM
  3. In screed fitting/valve access box.
    By solutions in forum Plumbing Forum
    Last Post: 08-07-2014, 12:13 AM
  4. access to boxed in low level wc to change ball valve
    By dean.diy in forum Sanitary Ware
    Last Post: 04-09-2012, 08:54 PM
