Chatrooms
New toilet -
Go Back   Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK > Plumbing Forums > Sanitary Ware
Notices
Old 07-02-2010   #1 (permalink)
Tonto123
Info
Default New toilet
Have a low level toilet... Thinking bout installing a close coupled toilet.. my question is would i have to move the 4inch waste if i wanted to install a close coupled toilet cause that would be tricky....
Tonto123 is offline
Old 07-02-2010   #2 (permalink)
WHPES
Info
Default Re: New toilet
Depends where it is and which CC toilet you are looking at. Does it go through the wall or into the floor? You can look up dimensions of most of the man brands on the net to check. Some are nearer than others. A popular one is the Sandringham and the dimensions are here:
http://www.armitage-shanks.co.uk/fil...gham6_ccwc.jpg
You can fit an offset pan connector into the wall outlet, or a return bend into the floor. The thing you have to watch in the case of wall outlets is that the outlet is not significantly higher than the pan outlet, and in the case of floor outlets, that the pipe is too far into the room to prevent the WC from sitting against the wall.
WHPES is online now
Old 07-02-2010   #3 (permalink)
Tonto123
Info
Cheers bud.... it comes out of the floor... looking a a few ccs and i dont think the cistern would be flush with the back wall... so think il have to use a low level.. dont want to take up floor boards etc...
Tonto123 is offline
Old 07-02-2010   #4 (permalink)
puddle
Info
Just put wood support behind cistern to allow pan and cistern to sit forward slightly to allow access to drain and then just fit a few tiles over wood frame and away you go,usually only have to pack cistern out about 2"
__________________
work hard,play harder
puddle is online now
Smelly toilet - help mrdavy36 Plumbing Forum 7 25-01-2010 04:57 PM
Enclosed Toilet Seat emg1967 Plumbing Forum 5 26-10-2009 09:33 AM
Toilet dual flush problem! johntmanic Sanitary Ware 8 05-10-2009 10:12 PM
HELP - all out of ideas - toilet problem serenity_aus Plumbing Forum 12 27-04-2009 05:12 AM
Toilet cistern - does it always have to be immediately behind the toilet? Benedict Plumbing Forum 1 21-07-2008 11:21 AM
