Results 1 to 12 of 12
Plumbing & Plumbers Forum - Toilet cistern - fix to wall
Discuss Toilet cistern - fix to wall in the Sanitary Ware at Plumbers Forums; Hello Friends Just fixed my toilet with a new inlet valve, simple but I had to take the cistern from the wall to get to the underneath properly, all OK, ...-
14-06-2012 #1Plumbers Arms member
- Apr 2011
- Langley, Berkshire
- 681
- 200
- Thanked 9 Times in 9 Posts
Hello Friends
Just fixed my toilet with a new inlet valve, simple but I had to take the cistern from the wall to get to the underneath properly, all OK, no leaks which is the main thing and flushing properly with no intermittent filling (was getting on my nerves all through the night!).
The cistern is now a little loose from the wall, can you please advise what are the best fixings please?
At present there are 2 large bolts but the seem to go in the wall but not fix to anything and so are easily removed!!!
I want to fix it correctly so the job is done once.
Hope to hear from you soon.
Best regards
Rocket.
14-06-2012 #2UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
Screws with tap washers then metal washer
Tap washer to protect cistern
Metal washer to give good fixing
Screw. Fairly obvious the function of this
"nothing is impossible"
14-06-2012 #3Plumbers Arms member
- Apr 2011
- 681
- 200
Re: Toilet cistern - fix to wall
Thanks Simonjohns,
I thoguht it would be some sort of screw somehow!! I am not that dim but wanted to know whether there is a better fixing like some sort of bolt maybe?
Ar present its a thick bolt but as I say doesn't screw into anything.
Thanks for your reply
14-06-2012 #4UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,044
- 512
- Thanked 677 Times in 611 Posts
If it's a close coupled wc I wouldn't worry too much about it.
If you're going to do things properly, then polyfilla the holes and start again with another rawplug.
Then when the polyfilla falls out after drilling, polyfilla the holes and start again with another rawplug.
Then try siliconing the screws in.
Then give up.
The weight of the cistern will be on the pan and the butterfly nuts will stop most forward/backward movement. It shouldn't go anywhere unless someone is intent on kicking it hard.
If it's a low level wc, then a couple of square brackets for the cistern to sit on will take the weight and hit and hope with the wall repair.I'm not a complete idiot; some parts are missing
14-06-2012 #5Plumbers Arms member
- Apr 2011
- 681
- 200
Hi DNITALL
Thanks for yuro reply.
It is a close coupled toilet,
I'll will have a go at the weekend as it is lose and i'd rather have it fixed as there is some movement.
Cheers
Rocket.
14-06-2012 #6UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,044
- 512
If it's a little wobbly I'd suggest fitting a new doughnut ring/washer and tightening the butterfly nuts up more (possibly buy a couple of new ones.) Any local plumbing merchant can help you with these and shouldn't charge more than £5. Best to take in the doughnut first though so they give you a suitable replacement.
Doing this will make the rear screws just about redundant and give you a more secure wc.I'm not a complete idiot; some parts are missing
14-06-2012 #7Plumbers Arms member
- Apr 2011
- 681
- 200
Sorry, not wobbly to the pan but against the wall. I'll sort it.
Thanks again.
14-06-2012 #8Plumbers Arms member
- Apr 2011
- 681
- 200
it may also be the floor might not be 100% level.
15-06-2012 #9Top Plumbing Forum Contributor
- Apr 2011
- 751
silicone
15-06-2012 #10
15-06-2012 #11Top Plumbing Forum Contributor
- Apr 2011
- 751
Underneath me on way to silicone shop
18-06-2012 #12UK Plumbersforums Trusted Advisor.
- east london
- 6,666
- 9
sounds like the wall is poor fixing just pack some whittled down wood in and a new screw
Does a toilet cistern need to be screwed to the wall?
By payvpac in forum Sanitary WareReplies: 10Last Post: 08-04-2012, 11:42 AM -
Cistern not to wall
By ashwilson in forum Plumbing ForumReplies: 11Last Post: 07-08-2011, 07:31 PM -
not working toilet flush hande???back to wall toilet
By kasia in forum Sanitary WareReplies: 2Last Post: 01-08-2011, 12:49 AM -
Reusing concealed wall hung cistern and pan and wall hanging bracket
By eliew in forum Plumbing ForumReplies: 4Last Post: 24-01-2011, 08:54 PM -
Toilet cistern - does it always have to be immediately behind the toilet?
By Benedict in forum Plumbing ForumReplies: 1Last Post: 21-07-2008, 11:21 AM
2Likes
Been Here a few weeks.
2 Hours Ago in New Member Introductions
