Results 1 to 15 of 18
Plumbing & Plumbers Forum - tiling around a new shower installation
Like Tree3Likes
Discuss tiling around a new shower installation in the Sanitary Ware at Plumbers Forums; Not sure if this is in the corrtect forum but when tiling around a new shower installation what is the difference between applying cement to the back of the tile ...
    18
    Default tiling around a new shower installation
    Not sure if this is in the corrtect forum but when tiling around a new shower installation what is the difference between applying cement to the back of the tile or to the wall? The cement I have says apply it to the wall and not the tile. Does it really make a difference?
    Regards
    Steady Plumbing Forum Contributor nickelarsed's Avatar
    Aug 2011
    Sussex
    178
    Default Re: tiling around a new shower installation
    It definately does but I'm trying to remember why. They did tell me on my course, apart from the fact it's easier to get the tiles nice and level I think it's something to do with air, the adhesive gives off air as it sets which is why you use a notched trowel, so the air can escape, if you apply it onto the tile and then stick to the wall, this does not happen so easily. I think that's why, but a tiler may come along and say thats balls
    steveb's Avatar
    Nov 2007
    hythe hampshire
    8,969
    i hope you're using powdered adhesive and not tubbed
    18
    No, I am using ready mixed cement. Does it make a difference?
    Regards
    Aug 2011
    Sussex
    178
    In my experience BAL is fine for that as long as you pick appropriate one, I steer clear of most others.
    steveb's Avatar
    Nov 2007
    hythe hampshire
    8,969
    Quote Originally Posted by tonytimms View Post
    Regards
    yes it takes ages to dry and isn't waterproof. i had to change a built in shower which required the removal of two tiles they popped off too easily because the "tiler" had used tubbed. i could even reuse the old tiles just soaked them in hot water and the addy dissolved! also you have to wait for a couple of days at least before grouting, with powdered you can grout the next day.
    Aug 2011
    Sussex
    178
    Bal do a tubbed adhesive which is designed for this application. Can't remember which colour, but tilers shop would inform you. In general steveb is right they are pretty useless from a tub, but I've had no probs with this one.
    7,206
    BAL Whitestar or the Grip.
    Depends on the tile, tile size, substrate etc if you butter the back of the tile or not. I have some slate to do next week, so it will be notched on the walls/floor and butter the back of the slate. Gives better adhesion. This will be powdered adhesive though.
    Aug 2011
    Sussex
    178
    Simon, this thread has got me trying to remember my tiling course from a couple of years back, was that stuff I'm remembering about the air escaping rubbish, it's bugging me now I've said it.
    7,206
    Honestly don't know. I was told it was to do with the amount of contact of adhesive between tile and surface it's going on. Also depends on how straight your walls are as well
  11. The Following User Says Thank You to SimonG For This Useful Post:
    nickelarsed (09-03-2012)
    Plumbers Arms member MattWeth's Avatar
    Cheshire
    453
    Quote Originally Posted by nickelarsed View Post
    It's kind of right but it isn't the air escaping during the adhesive cure, the notched adhesive lets the air escape while you bed the tile down. The notches stop any bubbles of air being trapped behind the tile as it can squish out along the channels until the tile is fully bedded. If you just trowled a full bed on (like plastering), you could easily trap big bubbles behind the tile as you bedded it.
    At least that's what my tiler mate says
    SimonG and nickelarsed like this.
  13. #12
    Jan 2008
    North Yorkshire
    4,149
    Tubbed adhesive takes about 8 days to set before you can grout. Powdered adhesive you can grout after 24 hours. Never used tub adhesive myself.
  14. #13
    dancinplumba's Avatar
    Beautiful Barlick
    5,360
    you get your o rings whpes ?
    >>>>>>>>>> I'M DANCIN, YOU ASKIN ? <<<<<<<<<<
    GSR? Want gas safety or boiler repair advice? We will check out that you're genuine via the gas safe website, so please dont be offended when we ask for your details. DIYers, odd job people and have a go heroes need not apply
  15. #14
    Aug 2011
    Sussex
    178
  16. #15
    Beautiful Barlick
    5,360
    you have to let the moisture evaporate from the adhesive with tubbed, the others its a chemical reaction
    imo
  1. shower installation
    By marko1965 in forum Bathrooms, Showers and Wetrooms
    Last Post: 09-11-2010, 07:55 AM
  2. Shower Tray/Valve and Tiling
    By Amatuer in forum Bathrooms, Showers and Wetrooms
    Last Post: 14-06-2010, 08:17 AM
  3. ContractorForum: Tiling a bathroom with Bal Whitestar: hi all, im tiling a bathroom
    By Dan in forum Links, Forum Updates, News and Site Suggestions
    Last Post: 28-12-2009, 08:00 PM
  4. Shower pump needed but tiling already done!
    By tatty in forum Bathrooms, Showers and Wetrooms
    Last Post: 16-11-2009, 09:00 PM
  5. Shower installation
    By sali in forum Plumbing Forum
    Last Post: 01-08-2009, 11:56 AM
tiling around a shower
tiling around a shower forum
tiling around shower plumbing
plumber tiled around shower
