Plumbing & Plumbers Forum - Dual flush button sticking
Discuss Dual flush button sticking in the Sanitary Ware at Plumbers Forums; I have had this problem awhile now and tried wd40 and seemed to work for a bit. When you flush the big button on the dual flush It sometimes stays ...
    Paul O'Flynn
    Default Dual flush button sticking
    When you flush the big button on the dual flush It sometimes stays down so water trickles in all the time until you give it another tap and it comes back to the top positon.
    How can I stop it doing this or do I need to change the whole flush system.
    7,238
    Default Re: Dual flush button sticking
    Get some silicone grease on all the moving parts on the drop valve and in the push button.
  3. If You Burn It, It Can Kill You.
    Jan 2008
    North Yorkshire
    4,150
    If it's the cable type, check the cable isn't kinked where it goes into the flush valve.
    If you can't sort it, replace with the cable -less type.
  1. dual flush
    By stokedan1 in forum Plumbing Forum
    Last Post: 10-06-2011, 07:07 PM
  2. problem flushing ideal standard dual flush (full flush)
    By Aquaplumb in forum Plumbing Forum
    Last Post: 11-02-2011, 08:39 PM
  3. push button Dual flush valve
    By Nas in forum Plumbing Forum
    Last Post: 27-08-2010, 08:23 AM
  4. 2-button Flush .... what to press?
    By blinkinhek in forum Plumbing Forum
    Last Post: 17-05-2010, 04:19 PM
  5. Dual Flush
    By claire21 in forum Sanitary Ware
    Last Post: 12-10-2009, 10:01 PM
button stuck down on cable flush valve
push button flush sticking
dual flush valve sticking
dual flush button problems
dual flush sticking
push button flush stuck
flush button stuck
