Plumbing Forum Plumbing Forum Plumbing Forum Plumbing Forum Plumbing Forum
Plumbing Forum | Plumbers Forums | A forum for plumbers in the UK Plumbing Forum Sponsorship Armadillo Workwear for Plumbers Drill Tough Objects Plumbing Forum Sponsorship
Plumbing Forum | Plumbers Forums | A forum for plumbers in the UK » Plumbing Forums » Sanitary Ware
Sanitary Ware Subjects related to sanitary ware are in this forum.
Old 20-01-2008   #1 (permalink)
koibloke
Default Waste through joists
Fitting a shower tray directly onto 9'' x 3'' joists. Am I OK taking the 1½'' waste through the joists to couple to existing waste pipe. Sound advice much appreciated.
koibloke is offline   Reply With Quote
Old 20-01-2008   #2 (permalink)
uug197h
Default Re: Waste through joists
If you are cutting a hole in the joist then its best if you screw a block of wood under the hole about 8" long and put nogins in (wood from 1 joist to the other) i also put a metel strap on the top of the joist better safe than sorry
__________________
Plumbing Forum Moderator
Old 24-02-2008   #3 (permalink)
Matty A
I would advise checkin how many other holes are in the same joist that are near to where you are going to put your waste as not to weaken too much in one place.
If there are too many holes in then you can cut a lengh of 18mm pine ply 9" wide then glue and screw to the joist then drill your hole through the ply as well also brace between joists wi noggins ( as uug197h) said..
Old 03-03-2008   #4 (permalink)
nick penfold
building regs state that holes in joists should be no more than one quarter the depth of the joist.
nick penfold is offline   Reply With Quote
Old 3 Weeks Ago   #5 (permalink)
TerryH
Koibloke,
The figures I have are different to Nick's.
To notch into the joist you should be between 7% and 25% of the lenght of the joist away from the wall. The notch should be no more than 1/8th of the depth of the joist.
Obviously a difference of opinion there!
Terry.
TerryH is offline   Reply With Quote
Old 3 Weeks Ago   #6 (permalink)
ajs heating
yes as you say 7 - 25 of the length. depending on span of joist.
max depth of notch will give you 28.75mm
max size bored hole will give you 57.50mm
__________________
ajs heating is offline   Reply With Quote
Old 2 Weeks Ago   #7 (permalink)
nick penfold
yes yes guys you are right. notches no more than one eighth etc but we were TALKING about HOLES. If your drilling a hole through the joist, it must be no more in diamater than one quarter the depth of the joist.
Sorry if i confused people with the previous post )
You may post new threads
You may post replies
vB code is On
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
