Plumbing & Plumbers Forum - Toilet bowl connected to Uralite pipe
Discuss Toilet bowl connected to Uralite pipe in the Sanitary Ware at Plumbers Forums; Hi, This is a toilet bowl, which was not properly installed - there seem to be gaps in the silicone, where the bowl connects to the waste pipe, which looks ...-
30-06-2010 #1New to Plumbing Forum
- Dec 2008
- 28
Hi, This is a toilet bowl, which was not properly installed - there seem to be gaps in the silicone, where the bowl connects to the waste pipe, which looks like some kind of uralite to me. In fact there doesn't seem to be any leaking, but there is some odour. So I was thinking of some easy way to solve this, short of re-installing the toilet. My question is, do you think it would work if I first apply something like American tape tightly around the waste pipe, so that new a new silicone bead would have something to adhere to? Or I wonder if a little gloss paint on the uralite might also work? Thank you.
30-06-2010 #2Banned
- Jul 2009
- North Devon
- 1,889
- 5
- Thanked 86 Times in 76 Posts
Re: Toilet bowl connected to Uralite pipe
you can either have a proper plumber into do a decent job or carry on botching as described
30-06-2010 #3New to Plumbing Forum
- Dec 2008
- 28
Thank you for the reply. I agree that the proper solution would be re-installing the toilet bowl.
20-08-2010 #4Steady Plumbing Forum Contributor
- Jun 2010
- Wiltshire
- 121
- 12
- Thanked 2 Times in 2 Posts
That sounds like an episode of BBC's Changing Rooms with Carol Smillie where neighbours do up each others house.
This woman ended up with a basement turned into a gothic dining room, she hated it.
But while it was being done there was a hole in the ceiling about the size of a large hand print, their solution was to cover it with brown 2" packing tape then paint over it.
The only thing that brown 2" packing tape should be used for other than boxes is taping people to chairs and taping them to a RSJ outside at about 3am.
Working in factories has got it's plus points, they can be a right laugh, and it was fun being taped up especially when they came out to see if I was alright and I was gone, they s*** themselves
they were looking everywhere.
But I could only get so far taped to a wheeled office chair, they grabbed me and taped me back up, couldn't figure out how I got out again either as they used even more tape than before.
Or should I have posted the second half in the correct forum
, this is a local shop for local people.
22-08-2010 #5UK Plumbersforums Trusted Advisor.
- Aug 2008
- 1,529
- Thanked 100 Times in 93 Posts
Hi The pipe you describe is probable pitch fiber. Why not remove pan and refit using a multikwik?
22-08-2010 #6UK Plumbersforums Trusted Advisor.
- Mar 2010
- lincolnshire
- 3,737
- 297
- Thanked 374 Times in 357 Posts
Uralite is a name used for asbestos pipe
23-08-2010 #7New to Plumbing Forum
- Dec 2008
- 28
If this toilet bowl was in my own house, I would just remove it and re-install it properly - there may be different views about how to connect to an asbestos pipe - in this case the cistern is about 1,5 / 2 inches from the back wall, so at least 2 inches would need to be sawn off the asbestos pipe as well. I would probably stick an adaptor inside the asbestos pipe , possibly (carefully) with rapid cement or really good silicone (some of you may have better suggestions?), and then insert the toilet bowl as normal, using a rubber ring, (if space permitted).
But since I donīt think the person responsible for the flat wants to do the job, I thought if I could do some workaround that wouldn't damage anything...like a little tape, to block off the odour (though an odour in itself is definitely reason enough for re-installing the bowl). So yes, of course I absolutely agree, the toilet *should definitely be removed and installed properly. Thanks.
Toilet & Basin Waste Pipe Problem !
By Monkey Wrench in forum Plumbing ForumReplies: 0Last Post: 07-06-2010, 08:04 AM -
Mysterious pipe on toilet... help!
By Lextek in forum Plumbing ForumReplies: 4Last Post: 05-10-2009, 12:40 PM -
Moving the toilet waste pipe in floor
By eetsteamleader in forum Sanitary WareReplies: 1Last Post: 19-08-2009, 11:25 PM -
Toilet bowl and seat problem
By jhatter in forum Sanitary WareReplies: 1Last Post: 21-05-2009, 10:53 AM -
Toilet and 32mm waste into same pipe
By MikeHowles in forum Plumbing ForumReplies: 4Last Post: 10-05-2009, 08:25 PM
boiler and heating system advice
5 Minutes Ago in Central Heating Forum
