Results 1 to 12 of 13
Plumbing & Plumbers Forum - Connecting two toilets
Discuss Connecting two toilets at UK Plumbers Forums; Hi everyone Can you tell me if it is possible to connect a new toilet to an existing toilet in the adjacent room by using some sort of connecting pipe ...
    bevan
    Default Connecting two toilets
    Hi everyone
    Can you tell me if it is possible to connect a new toilet to an existing toilet in the adjacent room by using some sort of connecting pipe through the wall between the two toilets and then have the waste from both toilets to go out into one soil pipe, which is attached to the existing toilet. Would this work or would the flush power in the existing toilet be reduced as a result?
    Would welcome advice asap
    Thank you
    dontknowitall's Avatar
    Apr 2008
    Herefordshire
    6,122
    Default Re: Connecting two toilets
    I went to a house where this was the arrangement (not my installment I hasten to add.) Both toilets flush well as expected.
    But - one toilet drains as expected but the other sends its waste via the first toilet then down the soil pipe.
    From this experience, if I were you I'd have both horizontal soil pipes entering the vertical waste at different levels so there's no chance of waste travelling horizontally.
    Also, I have a feeling there's something in the water regs about this situation.
    bevan
    Thank you v.much dontknowitall - that seems very sound advice
    Apr 2008
    A, A
    121
    Yes, there's definitely guidance in the Water Regs about this;
    they have to be separated by height or angle into the stack. Check it out otherwise you'll have waste chugging back up your pipes, mate!
    ADMINISTRATOR REDSAW's Avatar
    Jan 2009
    Nottingham
    13,215
    no you cant, it is against b.r the way you describe it.
    i think it has to be 600mm up/down stream from other outlet
    ¿ʞɹoʍ sɐƃ
    Blackcatgas's Avatar
    Oct 2009
    Nottingham
    1,675
    Quote Originally Posted by REDSAW34 View Post
    I went out to a new bakery thats just been set up in Colwick to the staff w.cs, 4 toilets, back to back with y shaped tees and no fall in the soil pie as it went straight along horozontaly across the outlets terrible they had never worked properly and were always piled high with muck, They needed it doing sooner than I could fit them in so i couldnt remedy the probb, but i did get 2 delicous loafs and some choclate marble cake mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm Marble cake.
    Jan 2009
    Nottingham
    13,215
    Quote Originally Posted by Blackcatgas View Post
    thanks for thinking of me phil
    i bet they doubled up as a bidet on the other side when one flushd?
    ¿ʞɹoʍ sɐƃ
    charliejamesuk
    I think regarding Water Regs that two WCs can discharge into the Soil Stack at the same level but the connections into the Stack must be opposite each other.
    Feb 2009
    chesterfield
    850
    previous post is correct, it is permissable to have connections from two wc's in opposing posstions.
    Oct 2009
    Nottingham
    1,675
    Quote Originally Posted by andyg0507 View Post
    But doesnt work very well.
    Feb 2009
    chesterfield
    850
    yes blackcatgas, forgot to mention that bit
    Aug 2016
    Could you possibly provide a link to this information? I'm having the same problems with some work done.
  1. Blocked toilets
    By rocketmanbkk in forum Plumbing Forum
    Last Post: 19-03-2013, 06:53 AM
  2. What is it about toilets!
    By secret squirrel in forum Plumbing Forum
    Last Post: 22-02-2013, 06:19 PM
  3. B&Q Toilets (RAK) also taps
    By mcdougc in forum Sanitary Ware
    Last Post: 21-08-2012, 12:59 PM
  4. blocked toilets
    By desrob in forum Plumbing Forum
    Last Post: 13-08-2012, 11:02 PM
  5. Toilets
    By MattWeth in forum Plumbing Forum
    Last Post: 13-06-2012, 07:56 AM
  6. anyone fitted one of these toilets ?
    By johnnyplumb in forum Plumbing Forum
    Last Post: 06-03-2012, 03:01 PM
  7. Mains fed toilets?
    By Phil in forum Plumbing Forum
    Last Post: 15-01-2012, 10:24 AM
  8. pub toilets
    By Plumbstar Tom in forum Plumbing Forum
    Last Post: 16-06-2010, 01:33 PM
  9. Pub Toilets
    By WHPES in forum Plumbing Forum
    Last Post: 14-04-2010, 09:01 AM
  10. Which System Boiler?
    By Reepham2003 in forum Central Heating Forum
    Last Post: 17-11-2009, 10:43 PM
connecting two toilets to one soil pipe
2 toilets 1 soil pipe
two toilets one soil pipe
plumbing two toilets together
how to connect two toilets together
