Results 1 to 12 of 13
Plumbing & Plumbers Forum - Grant Spira Condensing Pellet Boiler
Like Tree4Likes
Discuss Grant Spira Condensing Pellet Boiler at UK Plumbers Forums; Anyone got experience of these? We've been looking for a quality pellet boiler at lower cost than the ETA's that we normally install. We have 'value' offerings from a well ...
    Member Worcester's Avatar
    Jun 2011
    973
    Default Grant Spira Condensing Pellet Boiler
    We have 'value' offerings from a well established UK company with a good reputation, however it isn't a 'name'
    The advantage of this - it comes with a brand, are they built by grant? Rebadged? Made where?
    Do they have any particular issues?
    I don't particularly like the type of burn back protection that tends to proliferate in this price range, though some other aspects of it look quite good for the price.
    Comments please
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    6,685
    Default Re: Grant Spira Condensing Pellet Boiler
    It's made by grant
    It's a condensing pellet boiler
    Limited on size it you want bigger it's 2 boilers ect
    They say they work better going direct into heating not into a buffer
    I've footed a few they are good enough
    In same league as eta I don't think so
    I fitted a hapero it was a great bit of kit and I would put that above the eta
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    6,685
    Grant are Made in Dublin
    Forum Thug
    croppie's Avatar
    23,814
    Condensing pellet boiler?
    Croppie
    (By the way, I'm commercial!)
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    6,685
    Yes mate it's a condensing wood pellet boiler
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    6,685
    Worcester likes this.
    Forum Thug
    croppie's Avatar
    23,814
    I'm seriously intrigued by this, Alex.
    How does the condense pipework not clog up?
    Croppie
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    6,685
    There is a mains supply on a solenoid valve it washes itself out every so many hours
    Flushes out the condensate trap
    croppie likes this.
    Jun 2011
    973
    Thanks guys, so it fits in that gap below Eta which is fine, as going forward not all our clients want to spend that much capital.
    We're off to Devizes for a half a days training soon (having met us and seen our work, they claimed we don't need the two days like everyone else - We'll take a full day from them though, as to cover all the fault finding and service items properly will take a bit longer than an hour.
    @Gray0689 Interesting way to mount an expansion vessel, hope they're strong anchor bolts on that for when the bladder / valve fails, not just a bit of pasterboard
    Yep they're insistent that it doesn't NEED a buffer, though did acknowledge that it could be even more efficient with one - they claim 92% without on.
    And yes it does condense, apparently uses the same condenser as their oil boiler range.
    May 2010
    3,451
    Iv seen the plastic pipe melted where it caught fire as it goes into the burner! Only a basic overheat stat on the hopper feed, it needed new o/h stat & plastic pipe etc... That was an early model, maybe improved now!
    BBBMechanical likes this.
    We cannot help non gsr's with technical gas or boiler questions. If we do Croppie gets upset and gives us chinese burns......
    Jun 2011
    973
    That's the purpose of the plastic pipe - it's supposed to melt as part of the burn back protection
    Not as sophisticated as ETA's gate feed which cannot burn back.
    It's a common and accepted burn back protection method, not one I'm a bog fan of though.
    Forum Thug
    croppie's Avatar
    23,814
    Quote Originally Posted by Gray0689 View Post
    Ahhhhhh I see!
    Croppie
  1. Pellet boiler
    By march1971dogs in forum Renewable Energy
    Last Post: 15-12-2015, 12:14 AM
  2. Replies: 7
    Last Post: 29-03-2015, 03:38 PM
  3. Replies: 6
    Last Post: 10-01-2015, 10:21 PM
  4. Grant Vortex 15/21 non condensing - overheat stat?
    By Bunker in forum Oil and Solid Fuel Forum
    Last Post: 24-02-2013, 01:43 AM
  5. Replies: 0
    Last Post: 27-02-2012, 09:00 PM
